Question about Garden
Changing from Pos ground generating system to Neg ground 1 wire alternator system. need wiring diagram. At present the minute the key is turned the engine starts tuning over. wiring had been repaired/spliced/ect when tractor bought and unable to track down wires or figure out proper placement to put in new wires.
    Brigadier General:
  • 4,088 Answers
It would seem best to just remove all of the original low voltage wiring completely. You won't need the 'cutout' device any more as the diodes in the alternator will replace that function. Does the ignition switch have a 'start' position? If not, then suggest finding a normally-open push button switch for a start button. Is the ignition system a points/coil/capacitor unit or a magneto. If a magneto, it needs to be grounded with a kill switch. If the points/coil system, then the key should apply power to the coil connection through a doubled resistor when running. You will also need a 12 volt battery of course. Change the starter solenoid to a 12 volt unit. The starter will draw about double the current used at 6 volts, but will likely survive if you don't 'grind' the engine. Depending on the tractor, there may be a 12 volt starter available that will fit. If you have an ammeter, it should be in series with the battery connection at the starter solenoid and the ignition, lights, and any other light loads (never in series with the large starter cable). That should cover most of your concerns, but understanding what I have written may be a concern. I don't have a wiring diagram specifically, so I hope this helps!
Posted on Sep 12, 2010
Convert battery cables from top post to side mount replacement ends?
If all you are doing is changing to a side post battery, just connect all the positive cables from the old pos post to the new pos holder and all the neg ones to the new neg holder. If you've already cut them all off and not sure where each wire goes, all the reds are positive, all the blacks are neg. To make sure use your continuity meter to test. Connect one meter lead to any good clean metal part on the car and test between each black wire in turn, the neg ones will show a circuit, the pos ones will not.
Feb 10, 2015 | 1993 Chrysler Concorde
How do you wire up 4 6 volt batteries in a 1976 kenworth. 12 volt lights 24 volt starter
When you go pos to neg from one battery to the next it increases voltage, pos to pos just increases amperage. You would want to wire 2 in series, just imagine stacking batteries in a flash light, pos from one to neg on next. Remaining pos and neg are 12v now. Run both remaining pos to starter and ground both negs. your pushing a lot of amps with the batteries and doing 12v, and your charging system is 12v. If you do another series from there, you have to regulate the voltage when the starter kicks in...you risk burning every light and electric component...just like running 12v in 6v system... You can also use 4 12v batteries and run all pos to pos and all neg to neg and have mega cranking amps...that is how all modern big trucks are set up. Your pushing around 7k cranking amps that way(1500 per battery)...plenty to start the healthiest cat... And don't have the worry of dual voltages or running in series. You really don't need 24v to start and unless you have a 24v alternator, these are your 2 options. Best bet if your not sure is to try with 12v...no risk of frying anything even on 24v system. 24v on 12v system is, on the other hand, a big risk. 43bf17ec-4e37-4a15-a147-d1e7a1377d9f.jpg
Jun 03, 2014 | Cars & Trucks
Wiring diagram for Kenwood KRC-2007?
red wire is key source black wire is ground yellow wire is menory 12 v source is that is on all time rest are speaker wires make sure u put the full color wires as ur pos side then the wires with a blk line thur is neg side
May 15, 2010 | Kenwood KRC-2007 Cassette Player
Does anyone haven a wiring diagram for a quad 4ohm voice coil subwoofer?
Basic wiring dictates that with a speaker with 4 voice coils all at 4 ohms each is meant to be wired in parallel. This will put the load at a 1 ohm total load on the amplifier. Wiring in parallel is positive out from amp to pos. to pos. to pos. to pos.. And neg. out from amp to neg., to neg., to neg., to neg..
Apr 09, 2010 | Eclipse SW9182Pro Car Speaker
Window will not roll up on 1990 toyota 4 runner
no power or no ground ??
try running a hot line to the motor
run a pair of wires from the batterie 1 pos 1 neg speaker wire will do
unplug the window motor and run it direct pos on 1 wire neg on the other flip the wires to change motor direction
if motor works then it's eithor a bad ground or a bad wire or a bad reley
Jan 01, 2010 | 1990 Toyota 4Runner
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car audio
zeus_s007- This is a pretty technical,request so i hope you understand my instructions. I hope the harness plug is present,this makes it easier.First of all i'll give you the wire colors,there are a couple the same color and we will start there.
tan-left front speaker-positive
gray-left front speaker-negative
light green-right front speaker-pos.
dark green-right front sreaker-neg.
brown-left rear speaker-pos.
yellow-left rear speaker-neg.
dark blue-right rear speaker-pos.
light blue-right rear speaker-neg.
orange-12volt constant-memory
black-ground
yellow- 12volt key switched-may be bigger than yellow speaker wire-we can check the wires,will explain later.
gray - dash dimmer
brown-dash dimmer
You don't need the last 2 mentioned,any others left over not needed.
The safest way to check the 2 brown,grey,and yellow is to use a AA battery, as a speaker tester.You take the colored wires for the speakers and touch the AA battery to them. For example you know the 2blue ones are right rear wires-so take the AA battery and touch one blue to the one end of the AA battery and the other end to the other blue wire, you will hear static on that speaker.This will let you know the 2 proper wires for the speaker,no static -wrong wire.you only have to do this for the grey,brown,and yellow wires.Well I hope I don't confuse you,if your not sure,let me know.Good luck, happy wiring.
cooltek Mar,5/08
Mar 04, 2008 | Audio Players & Recorders
PIONEER SUPERTUNER 3 KEH-P4200
tdohnke-So you need a wiring diagram,well lets see what we got
red-accessory-12volt key switched
black-ground
white-left front speaker-positive
white with black stripe-left front speaker negative
grey-right front speaker-pos.-
grey w/black stripe-right front-neg.
green-left rear-pos.
green w/black stripe-left rear-neg
purple-right rear-pos.
purple w/black stripe-right rear-neg.
blue- remote turn on
orange w/white stripe-dimmer-optional
Try out this diagram,they are pretty much all the same now,if I missed any let me know. cooltek Mar,4/08
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
