Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Starts but won't keep running . runs for a few seconds
  • nadeaur Sep 12, 2010
    Hi, the information you provided me was somewhat helpful... the real problem appears to be when the saw is started it runs full bore ...I have to kill it with the K switch to control the rpm's.
    I had to replace both fuel lines in gas tank .. they were split wear. Is it possible the lines are
    backwards ?
  • 10,865 Answers
Hello. Generally when this happens you have some debris in the carburator. Do this. First of all make sure that the air filter is clean and not overloaded with oil. Then check the spark plug. If you have not replaced it in a while, do so. Finally make sure the gas in the tank is fresh and new. If it has been in that tank for over one month pour it out and start with newly purchased fresh gas, with the right mix of 2 cycle oil in it.
OK, now get a can of starter fluid and an assistant. Start up the saw and spray enough starter fluid at the air intake to keep it running until it runs smoothly. This usually only take a minute or two. Joe
Posted on Sep 12, 2010
My van shut down while turning a corner.Now sarts and runs a few seconds then stops.if you try a few times will not start.next will start and run a few seconds and die as before.
Nothing I can think of would cause such a situation other than just too low on fuel for the pump to pick it up and keep it running. Have you checked the fuel level? I'm not saying anything other than the fact that your fuel gage could be showing an improper amount in the tank. Could also be a dirty fuel filter not allowing enough fuel through to keep it running.
Mar 26, 2018 | Cars & Trucks
03 subaru Legacy 2.5 won't start . Turns over but won't fire. I have replaced fuel pump , fuel filter , and the pressure regulator. Pure fuel in the intake and starts fine What could be the problem
Does it start and keep running? Or does it start and just run for a few seconds? If it starts and runs for a few seconds you need to check your fuses first. It could be the fuel pump or EFI fuse or a few others.
If you prime it and it keeps running, well, you've got me there.
Sep 12, 2015 | Subaru Cars & Trucks
Low fuel pressure. Won.t start but pump run.s then shuts off
Pump is only supposed to run a few seconds to prime system with key on. Should run in start position, but check for restricted fuel filter and for bad fuel pressure regulator.
Jul 14, 2015 | Cars & Trucks
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
My security failed light keeps coming on in my 2002 Jaguar and won't start. What can I do?
hook up battery charger on low amp charge, turn key to run position and leave it on for 20-30 min. then turn key off, wait a few seconds, then attempt to start. if that dosent work, let me know.
Feb 14, 2013 | Cars & Trucks
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
My jeep won't start unless I give it gas. It used
Did you clean the throttle body and plate of any carbon ?
Aug 27, 2017 | 1998 Jeep Grand Cherokee
I have a rule 1800 computerized pool cover pump. As soon as I plug it in, it runs a few seconds then shuts right off, WON"T keep running. (this is outside of the water, dry) any help?
That's a good thing. That pump uses resistance on the impeller to alert it to the presence of water. It will periodically start and run for a few seconds. If there is any water present, it will keep running, otherwise it will shut off until the next time it tries. Put it in water, and see if it works there.
Dec 12, 2008 | Rule H53sp 24mgra Swimming Pool Cover Pump...
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
54 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
