Question about Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick pro duo says file error. I have 1000 pictures on it that I cannot retrieve or look at. my other stick works just fine so it isn't the camera.
    Genius:
  • 1,035 Answers
Hi. This could be a virus issue on the memory stick. Plugged the memory stick to a laptop that has a card reader slot and run anti virus program. You should be able to view all the pictures to your computer. If pictures are hidden then there is a huge possiblity that the memory stick got a virus.
Posted on Sep 11, 2010
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My 64 G PKNY disc is giving me an error of corruptable and cannot be read. Can I retrieve this files I must have them back
You can try using a file recovery software like Sony 4GB Memory Stick PRO Duo. Once files are recovered, please format the drive to fat32 file system. It will then be blank, ready to write files back to it.
Jan 23, 2014 | Electronics - Others
What could have happened to my memory stick pro duo? I took pictures and was able to view them perfectly fine. When I went to deveolpe them I put the stick in the wrong slot that was too big. The sti
When you plug this memory stick into your computer and the computer cannot detect this memory stick then the memory stick is damaged and your photos cannot be retrieved.
Jan 06, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Error Viewing pix
Do not use a Memory Stick Pro Duo - High Speed , use a Memory Stick Pro Duo below 2 GB
Apr 16, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
Format error
If Duo Pro got hardware problem, then it can not be fixed and you can't retieve data on it. Regarding new memory stick, camera will check it and let you know about format it or not.
Jul 31, 2008 | Cameras
File error
I was having the same problem with my 4GB memory stick pro duo, when i took more than 50 pictures with my camera (dsc-w90) i would get the blue screen with the file error message. I'm guessing you bought the memory stick on ebay right? I bought mines there and it turns out it's a fake one. If you also bought it there then you most likely have a fake memory stick because I found out that most of the memory sticks sold on ebay are fake, to help you figure out if you have a fake one or not check out this guide or google fake memory stick pro duo. http://reviews.ebay.com/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W0QQugidZ10000000001236041
Dec 25, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Sony 4GB Memory Stick PRO Duo Memory Card Logo
94 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
