Question about Maytag Neptune MAH5500B Front Load Washer
What do i do when i put double the amount of soap in the washer
    Brigadier General:
  • 3,006 Answers
Nothing. But the wash load may need an additional rinse or two afterwards.
Posted on Sep 11, 2010
It take to lon to do a load what can I do or am I doing something wrong? thanks.
You must be adding an incorrect amount of soap. You must use HE soap and just a little of it at that. If you overdose the washer it will come down with a suds error and attempt to get rid of suds.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Every now and then yall need to clear out the filter of junk that gets in there.
Apr 06, 2011 | Washing Machines
My washer will only dislove the powder saop on warm or hot cycle and now it won't let any water in to the tub at all why
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
HE: (2) Tablespoons Per Wash load
Your service manual and more notes on LGs HERE
Dec 09, 2010 | LG WM-2277HW Front Load Washer
Where do i put the laundry detergent?
Top left is a drawer. Be sure you put it in the soap dispensing department. Put HE stuff in there. Do not put too much. The correct amount is as follows:
Any more than this and you will get errors and headaches.
Sep 20, 2010 | Maytag EPIC MFW9700S Front Load Washer
How do I clean my front load washer. the clothes are starting to smell musky
Try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell.
Thank you
Jul 03, 2010 | LG WM-2277HW Front Load Washer
Terrible smell in front loading LG washer
Thank you
Jun 17, 2010 | LG WM-2277HW Front Load Washer
My lg washer was working and suddenly a burning smell came out of it and we dont know how to make it work again
Thank you
Jun 07, 2010 | LG WM1814CW Front Load Washer
My washer wont drain, says SD and blinks f-21
Sd: Suds lock. Detergent overdose. Clean out the soap dispenser. Remove the bottom panel and open the pump drain. F21: Long drain. Possible cause: Clogged filter, clogged/failed pump. Run some loads without detergent then use these amounts:
Apr 15, 2010 | Kenmore 43142 Front Load Washer
After running the washer there is still water in the drum and it smells. How do I fix this
Hi, Try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load machine has a hidden mold odour coming from the machine somewhere, but I cant locate the origin.
you could try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell,
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Do Frigidaire Front Load Washers require H&E detergents?
The answer is YES. Nearly all front loader washers built for consumers are rated as high efficiency because of the small amount of water and electricity they use. This small amount of water, coupled with a wash tub that does not agitate continously, followed by a high speed final spin of 1200 rpms or higher, all equate to an overall energy savings as compared to a conventional top loader. Regular detergent is formulated to be used in a wash tub with a 35 gallon capacity. So, if you use that same detergent in a wash tub that uses 5 to 7 gallons of water (such as yours), you are in effect putting about 5 times the concentration in the washer. This can lead to soap scum build up which causes odors, soap deposits that remain in your clothing and can cause skin irritation, "SUDS" errors that stop the wash program due to too much suds in the wash tub, and premature wear on the drain pump motor and seals. In fact, most front loaders will have a disclaimer added in the owner';s manual that explains this. Most manufacturers will also void the warranty if it is discovered you are using improper detergent. Use HE detergent and pay attention to the label. Some of them are double (2X) and triple (3X) concentrated. I hope this helps you.
Nov 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
