Question about iLO 2600 Television
26" ILO digital T.V . won't pick up digital signals w/digital antanae.\r\nusing air in setup
  • golderspike Feb 21, 2011
    I have tried 3 different antenna's with this t.v and no luck... the antenn's do work on other t.v.'s
    could it be in the t.v.???????
  • iLO Master
  • 5,103 Answers
So called digital antennas are generally a gimmick. The important factor to receiving stations is the antenna position and strength relative to the incoming signal. (Digital signals are either enough for the tuner or you get "no signal".)
Look at antennaweb.org or tvfool.com to find out what stations are likely to be received in your area and the direction to rotate the antenna; plug your address in the search area. Antennaweb is very conservative in its channel list even though it assumes an external antenna. Tvfool gives a list of the channels you should get with various antennas (labelled by color). This is a standard label that will be on the antenna specs or box (at least on good antennas). Tall buildings and trees in the area can reduce the channels you receive.
Adding an amplifier may help you gain signal strength for borderline stations (or if you split the signal to several devices).
I hope this helps.
(My house has an external antenna with an amplifier/splitter. Antennaweb suggested that we'd only get the stations from ~10 miles away. We get those stations and the ones from ~30 miles away with the antenna rotated for the further stations.)
Posted on Sep 11, 2010
  • Cindy Wells Feb 21, 2011
    Assuming the other TVs were tested without moving the antennas, it could be a bad tuner with the tv. (Tuners do vary and some will require more signal to receive the stations.) Without knowing the antenna setup you tested, I can't rule out a weak signal issue.
    For an example of tuner variability, I have two tvs connected to a 4-way splitter amplifier and an outdoor antenna. When the antenna gets rotated by the wind, the primary tv receives a good signal. The second TV reads a bad signal strength. (Damage to the amplifier has a similar effect.) Cindy Wells
How do I hook up my digital cable to my ilo flat screen TV with out a box
It won't work because the tuner from your ilo TV will not be able to decode the digital signal from the cable company even if your TV has a digital tuner. The digital tuner on your TV will only decode over the air signals.
You will still need the digital cable box from the cable company.
Aug 03, 2015 | iLO Televison & Video
To hook up antena-do you need a special cable
No,buy a indoor digital antena have a wire already just plug the wire into the Ant. hole screw it in.Go into the tv menu goto SETUP.Go down to Ch.enter pick AIR enter again for scanning for free air broadcasting channels,after all done scanning.That it tv now have all free air broadcasting channels.
Jun 09, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Do i need to buy a converter box for this tv
No,this tv is a digital tv,just reqiure a good antena like a digital antena or a roof antena.Hook it up.Just go into tv menu setup and set up to pick up AIR not CABLE and enter to scan for DTV free air channels.
Feb 01, 2011 | RCA L26WD26D 26 in. LCD TV
I have the antenna plugged in to the tv, but I am not receiving any signal. I get a couple of channels, but none of the main ones.
Try buy a Digital antana design better signal stronger and longer ranges.Rescan again,u will get all the free DTV channels air broadcasting.
Dec 31, 2010 | Protron PLTV-37 37 in. LCD Television
How do i set the 2632 from cable to uhf/vhf antanna
Have a good antana like a roof or a HD antana plug into the ANT tv hole.Tv remote push the tv menu.Goto SETUP go down to CH.push and pick AIR not cable.Push for scan for free DTV tv channels.When finish scan u will have all the free DTV channels,depend how good is ur tv antana receptions is.
Nov 26, 2010 | Polaroid FLM-2632 Television
My jvc lcd does not work with my local air tv, i get weak signals
Ur tv is getting a free air DTV right?Not Cable tv,Satalite or Telicom compannies services?Yes,than.Get a better antana like a roof antana or Digital inside antana to get better stronger and longer ranges to recieve the signal.Go to ur tv Menu.Goto setup Ch. Pick AIR rescan all the free DTV signal again,u should get all channel and a strong signal.
Jul 29, 2010 | JVC LT-32E478 TV
Radio signal strength not very good
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
May 21, 2009 | Goodmans CD car radio GCE358MPT CD Player
Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Jan 13, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Air Digital No signal on the screen. Cannot change channels
hi my name is mark, since you have a cable box. you need to switch the tv back to the analog signal on the tv through setup or menu screen. then use cable remote to change channals. thanks for your question.
Dec 26, 2008 | Mintek DTV-263 26 in. LCD Television
Televison & Video Logo
403 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
