Question about Garden
Honda gcv 160 engine have to have the choke half way closed to run
  • 3,740 Answers
Hi. Remove the float bowl nut and cleanout the hole the float bowl nut screws into. Also clan out the side holes in the float bowl nut itself. There is debris in the bottom of the float bowl tht is restricting fuel flow. Pretty simple fix. Just make sure that you have the bowl gasket aligned when you re-install the float bowl. Otherwise it will leak fuel.
Thanks for choosing FixYa.
Kelly
Posted on Sep 12, 2010
Can u send me the Honda gcv 160 cc and 21 lawnmower engine start video step by step in my mail id
1 - make sure ignition switch is on
2 - make sure that gas switch to motor is in "on" position
3 - Set choke to start position
4 - fill with gas
5 - Pull on starter till starts then push choke back in.
Jun 10, 2017 | Honda Garden
Does this unit have an electronic fuel shutoff on the bottom of the carburetor?... If so, that is your problem. Otherwise, you will need to remove the carburetor, service it..
If u want test it first... Spray some carburetor cleaner into the plug hole then reinstall the plug. Start the engine, if it runs for a few seconds, u definitely have a fuel issue, carb....
U can buy a rebuild kit for the carburetor.
Also, go to you tube and search, how to service a 4 cycle carburetor..many videos to learn how...
Good curbside find!!
Oct 25, 2015 | Husqvarna HU700FH 22-in Self-Propelled...
How do I replace top crank seal honda GCV 160 engine
its not going to matter if the seal is leaking damage alreay done to it run it till it stops or lockes up
Aug 18, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
My Honda GCV front wheel drive got no throttle control. Start it with the choke on, choke slowly moves back to down position but then refs are to low. It runs smooth, but way to slow. What can I adjust or...
There is a governor adjustment on it.Find the governor spring coming from the carburetor the link will lead to a governor spring hooked to a metal tab,by bending the metal tab it will pull the spring tighter making the engine run at a higher rpm
Oct 20, 2013 | Garden
My honda cb750f will not run without the choke being out
Vacuum leak.
Check all mating surfaces, any place where a vacuum line attaches, with a short spray of carb cleaner while running, when you find the leak, it will smooth out and speed up on it's own. And if EGR equipped- make sure the EGR is closing fully when cold and when hot at idle.
Jun 01, 2012 | Honda Motorcycles
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN WHEN FULLY CHOKED
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 31, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
373 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
