Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
My DSS25KGRE WW GE Adora side by side refrigerator has intemittantly not made ice or dispense water until i emptied the ice tray, now it is a permanent condition, the freezer has thawed and then frozen and the vegatble bin tomatoe's were frozen. The freezer and cooler boxes get too warm and too cold. thanks Greg Munn
  • 3,083 Answers
Here's a general troubleshooting guide:
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5209136
It sounds, also, like this could be a defrosting cycle problem, and that would be the main control board. An ice line has possibly frozen to the icemaker
This page has some problems reported by owners of GE:
http://fixitnow.com/wp/2006/04/02/frigidaire-side-by-side-refrigerators-air-damper-control-problem-stuff-freezing-in-the-beer-compartment/
I'm thinking damper problem is probably what's going on, so check it to see that it opens and closes. There are new damper kits for some models, and may have one for yours.
Here is GE's support page:
http://www.geappliances.com/service_and_support/contact/
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 11, 2010
I have a GE Adora, side by side, the ice gets clogged in the blades of the crusher and prevents ice from dispensing.
It does sound as your water valve letting water to drip and it will fill and freeze. To check watch the ice cubes. Are they as cubes or all in one .
May 29, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
My GE Adora side by side will only dispense crushed ice...the buttons seem to be working, as in the light comes on each button when pushed. But only crushed ice!
Turn off icemaker. Remove ice bin, empty it, rinse with warm water and leave to dry overnight.
If this did not help - check solenoid in the freezer behind the ice bin, make sure it's not stuck and has continuity. If all checked out ok, but still no cubed ice - control board or interface board may need replacement, and you'll need a professional to diagnose that.
Good luck,
Vlad
First Choice Appliance
Jun 02, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Water/ice won't dispense - lights are on but when you depress the lever - the lights go off
The main board is bad. Not only are the lights going off but it also stops the refrigerator from cooling when the dispenser is used. I would tape a piece of paper over the dispenser until board is replaced.
Feb 25, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
THE ICE MAKER IS NOT WORKING. I emptied the Ice bin for a party and now the Ice maker will not make new cubes. The water line is fine and I still can get water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Ice maker problem
try turning down your water inlet pressure go about half way and play with it from there also check the tube going to the icemaker to put water in the maker make sure it is all the way into the ice maker
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
255 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
