Question about Victor 1560-4 Calculator
Victor 1560-4 calculator
Where can I get replacement parts for the tape holder on my calculator?
  • 2 more comments
  • Anonymous Jul 01, 2008
    Need support arm for paper roll!
  • laylajaded Jul 01, 2008
    Need support arms for this Victor calculator. One of mine broke off.
  • BFWStory Sep 25, 2008
    The arms which hold the tape are broken. Please advise regarding availabity of replacements.
  • Anonymous Jan 29, 2009
    The arms for the adding machine tape keep breaking. Where can I purchase the arms?
Http://www.victortech.com/accessories.asp
109640-01 (Arm Set) for $5.00
Posted on Mar 06, 2009
SUPER GLUE. When the arms on my machine kept breaking and I ran out of replacement arms from old machines I was desparate. Super glue really works.
Posted on May 27, 2010
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Mar 08, 2010 | Sharp EL-2630P Calculator
I have an Olivetti HD 9100 calculator. The paper
My texas instruments TI-83 has a dark scrren i can barley see the numbers what is wrong with it?
Aug 06, 2009 | Olivetti Office Equipment & Supplies
Tape holders are broken
Order them from the company... they'e pretty cheap.
May 14, 2009 | Victor 1260-2 Calculator
I have a Canon P23-DHV calculator and I cannot remember how to load the paper into it. I tried to read some of the solutions but could not ger any of them to open so I could actually see the solutions
  1. cut the paper/tape cleanly on a slight diagonal
  2. hang the paper/tape so it comes from under the roll
  3. insert the fresh cut into the slot on the back (between the power plug and tape roll holder)
  4. press the FEED button to advance the paper.
Now, does anyone know how to turn off this blasted auto-shut-off feature????
Jan 24, 2009 | Canon P23-DHV Calculator
Replacement for broken paper roll holder
There are universal glue on paper holders available email upstateos@adelphia.net
Feb 13, 2008 | Canon P23-DH Calculator
Paper Roll Replacement
i work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
sbeljin@mgnet.co.yu
Feb 01, 2008 | Victor 1240 Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Calculator tape holder
I love the calculator, had it for years but also need the tape holder replacement part.
Nov 21, 2007 | Casio DL 250LA Calculator
Victor 1560-4 Calculator Logo
794 people viewed this question
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
David Burbee
David Burbee
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
