Question about Moen & One Handle Tub & Shower Faucet
Tub works fine but also runs during shower. Worked great for many years and just got worse over time. Tina
    Problem Solver:
  • 15 Answers
You need a new tub spout with pop-up diverter. you can get one at any hardware store with a good plumbing selection. use Teflon tape on the male threads. tighten snugly only. if you must use a pipe wrench to get it perfectly straight, wrap a rag around the spout so you don't mar the finish.
Posted on Sep 16, 2010
Our washer just started making loud popping noises while running. It still washes just fine
Some washing machines are made with hardened plastic parts instead of metal. You may have a plastic knuckle( used during the wash cycle to aggitate the items) that has worn a bit and needs replaced. I had the same issue with our Kenmore a few years back. The replacement knuckle was $100 plus tax. If you are handy with instructions and your hands it is something that can be done at home with the proper tools and time. I had no time to fix ours and the service charge cost $150.
Jun 03, 2012 | Maytag Neptune Washer
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Do you have written instructions for taking out an old faucet and replacing it with the INS898D-3/09 faucet? The directions that came with are just pictures and I need more explanation.
Good for you taking on this project. The first thing I will start with, is if you are not comfortable soldering copper then I would stop and call in a plumber to install the shower. If you have soldered copper in the past and are comfortable doing so then please proceed. Give yourself 2 to 3 full days to complete the project. You will need: Plumbing permit, available from your local munucipality. It will need to be inspected after the work is completed. Solder, solder flux and propane torch Heavy suede work gloves Water Spray bottle Pipe wrench Safety Glasses Hacksaw Deburring tool for copper pipe Emery cloth Tape measure Screw driver or screw gun Mounting Screws Old blankets 5 gallon pail 1/2" Copper pipe and fittings To begin we will have to uninstall the old shower. I find it helps to take photographs of the existing system so that you can see how the new one should go back together in case you get stuck halfway through the project and cannot see how to finish it off correctly. If you can access the shower from the other side of the wall, great. If not you will need to remove the shower surround or tile on the end wall where the plumbing is. Be sure to protect the tub with an old comforter or something to keep the tub from getting scratched up during construction. Before removing the old shower be sure to locate the shut off valves and close them. Turn both hot and cold on in the shower to remove any water pressure in the lines. Disassemble all the trim pieces of the old shower including the tub spout, handles, diverter and shower head. Take measurements of the existing piping to assist you when it comes time to cut and assemble the new copper. Do not reuse any of the old fittings. They will be very difficult to solder and new ones are very cheap. You should have 2 copper risers coming out of the floor, one cold, one hot. Cut them approx 12" above the floor. Repeat the same process for the tub spout and the shower riser. With all 4 pipes cut you can now remove the brass manifold from the 2X4 blocking. Disassemble the shower flange pipe from the copper shower riser. You should now have just the cut copper risers coming out of the floor. Use the deburring tool to clean the sharp edges where you cut the risers. This will aid in soldering the new pipe in and avoid you cutting yourself on the sharp copper while you work. To be continued.
Now that everything is apart it is time to cut all the copper to proper size and mount the brass manifold on the blocking within the wall. Take a close look at the drawings on the instructions. The plastic piece that covers the brass manifold will need to be flush with the drywall so that when you install the escutcheon plate it is also flush with the drywall. Be sure to test fit all the plumbing before soldering to ensure. begin by soldering the fittings that will screw into the manifold. Once this is done begin reconnecting the plumbing system. Again I can't stress enough that if you are not comfortable or have experience soldering copper to bring in a licensed pro. Nothing worse than completing the job and finding its either not up to code or worse leaks and you have to back over the job. Good luck with your project and let me know if I can be of any further help. Sorry it took so long to finish this. I was out sick for about a week right after I completed the first part. Good luck.
Aug 03, 2010 | Moen & One Handle Tub & Shower Faucet
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
I hit the power button and NOTHING happens. It worked fine the other day and now nothing What should I do?
Mine too. It has very few hours on it (though 3 years old now), worked great up to the other day then now couldn't be more dead than it is. Is it repair shop time, or worse?
Jun 13, 2009 | Sony STR-DE197 Receiver
Moen & One Handle Tub & Shower Faucet  Logo
60 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
