Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Unballenced on spin even when empty - Whirlpool Cabrio WTW6600SBT Top Load Washer
It may come up an unbalanced load but it may a sensor that is on recall. I have a Whirlpool Cabrio top loader and after I start it it says F1 which is a sensor on recall and I have to restart it several times before it continues the load. Go to their web site and you can look up the exact model to see if yours has a recall as well.
Posted on Sep 11, 2010
Washer not spinning.
IF IT IS EMPTYING THE WASHER LISTEN FOR A SWITCH TO CLICK AFTER IT HAS STOPPED BEING EMPTIED IF YOU DON'T HERE ONE THE SWITCH IS NOT WORKING AND IT WILL NOT LET IT SPIN WITH WATER STILL IN THE SYSTEM EVEN WHEN IT EMPTY AS IT THINKS IT'S STILL FULL I HOPE THIS WILL HELP YOU
Nov 05, 2014 | Washing Machines
Samsung b1445v front load washing machine will not pass prog. 8 even when empty, then code ue
This is an error caused by the cycle advance which acts like a timer. The main control board can cause this issue. Diagnostic testing will need to be performed to determine the cause of this problem
Jun 05, 2012 | Samsung Washing Machines
When you turn it on its making buzzy sound even im not flug in
One, You may Have a bad 1/4" jack on the Input, or Two you may have unballenced Bias on the Output Tubes. This is a technical adjustment in the Amplifier.
Oct 09, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Will spin on empty, but not with load in.
  • this is like this we have to get a sattilite worker to put it under it to solve it
Feb 16, 2009 | Zanussi FJD1666W Front Load Washer
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,290 people viewed this question
Dan Webster
Dan Webster
Sal De
