Question about Panasonic PT-44LCX65 Television
Lime Green spot in ceter of sceen
When watching the tv if a person is in the center of the screen there is a lime green to yellow 2" diameter spot on there face. What would cause this?
  • 01michelob Jun 20, 2008
    I have the same problem...spots that wont go away. I emailed Panasonic and they gave me a case number and asked me to call a 800 number. Technical assistance at that number had me do a few things and transferred me to service where they scheduled a no cost in home repair through a local repair center. They referred to the spots as "fuzzy spots". They said I wont pay for the service call or repair. Hope this helps.
  • Anonymous Jun 28, 2008
    I have a large green spot that shows on my screen. Sometimes if you look close it has a cross hair or a + in the middle of the green spot, I am not sure if the bulb is going out again for the 3rd time or not.
  • 868 Answers
Degauss
Posted on Jun 03, 2008
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
When watching a movie, on the bottom left of the screen is discolored. like on the blue screen, its lime green
This problem only happens when there is something magnetic in by the tv where the screen is lime green. Good luck!!!! hope this little bit of info helps
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
What causes a light green spot about 4# diameter at 8 oclock between center and bottom left. the spot is lime green.
This set (model number indicated) has three picture tubes, it is quite possible something like dust or dirt is covering part of one, unplug set and remove back cover and wipe the three lens with a lens cloth or a paper towel with glass cleaner sprayed on it, look for anything obstructing any of the three lens.
LET ME KNOW WHAT YOU FIND AND IF YOU NEED HELP COMMENT HERE AND THE SITE WILL EMAIL ME SO I can assist you.
SD TECH
Nov 26, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Yellow-green spot in center of screen
Defective light engine. Contact Sony support. They warrantied a lot of these sets even after the warranty had expired because of so many going bad after 3-4 yrs. Have the complete model and serial number ready when you call them.
May 20, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Jan 14, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Green spots
Good Day;
It sounds like the TV has foreign objects on the tubes, lenses or inner-screen, such as dust or bugs.l Remove screen from the front and observe.
If it were a TV problem the spots would be near the center of the picture.
Good Luck.
Jun 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Panasonic PT-44LCX65 Television Logo
300 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
