My Hp Dvd640 driver is not showing up. I can open the driver so apparently i have power to it, but once i place a CD in the drive it doesn't read it, nor does it show up when i pull up My Computer. So if someone could help me with this problem, i would be greatly appreciative. My OS is XP Professional.
CordellNJ
  • 21 Answers
SOURCE: my CD RW/COMBO drive is not visible in My computer
Removing Drive in Device Manager
Remove the drive name from Device Manager:
Select the drive name.
Click the Uninstall or Remove button (in Windows XP this is the square button with a red X, ).
Click Yes or OK to remove the CD listing.
Do not restart the computer.
Close Device Manager .
If your computer has Windows XP, restart computer!
Posted on Dec 13, 2007
SOURCE: TEAC DW-224E-B [CD-ROM drive]
Fail could mean a lot of things but those diagnostics (If I remember correctly) look at hardware. If you have a more concise message than just fail (I seem to remember they were) and it points at the cd/dvd first check the connection and if you happen to have an old cd player around try it...if it works and the other does not you have solved the problem. There is more to this but try this first .....FYI...if you were thinking of upgrading to a lightscribe or just wanted to have an extra CD ($10) it may be in your time interest to get one. Much more could mean anything from a bad cable to motherboard problem to....???? This is a start only....let me know....Tango
Posted on Jan 25, 2008
hothawk
  • 174 Answers
SOURCE: cd/rom drive door will not
take a long pin or straigten paper clip and find a hole infront on the drive insert it and gently push it till open.
Take care sometimes u see cd disc spin while it come out dont touch it until it stop
Posted on Sep 29, 2008
  • 13433 Answers
SOURCE: USB 250 zip drive not displayed
Hey, lost connection with you
Thanks,
Ekse
Posted on Oct 29, 2008
Teis
  • 340 Answers
SOURCE: no driver for the scanner hp officejet 9130 all-in-one priter
You obtain the driver the for HP office 9100 series, here.
- it is on purpose that I want you to download the older PCL5 driver, asthe new PCL6 can course problems.
If any problems, against all ods, should arise, do write back and I will be here to help you. 69d4c1a.png Regards
/Teis
Posted on Dec 21, 2008
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
I have an HP pavilion slimline s3600f desktop pc and the optical disk drive doesn't seem to be reading cd's or DVD's.
Check the Device Manager to make sure that the OS does not have any issues with the device. If there is an exclamation point ( ! ), then Windows has issue with it. If there is an " ! " then right-click on the device and select update driver.
If the drive shows in My Computer, right-click on the drive and select "eject" from the list. This will verify that the OS is talking to the device.
Check your BIOS settings to make sure that it appears in the BIOS and is not disabled.
Also, Microsoft recently released an update to disable Auto-Play on CD/DVD drives. If Auto-Play isn't working (due to this update), then put a music/movie cd/dvd into the drive and open Windows Media player and try to play the disc through there.
The drive may not be "broken" it just may be that auto-play has been turned off by Microsoft.
May 24, 2011 | HP Pavilion Slimline s3600f Desktop PC
Acer 4520 unable to read the CD DVD ROM drive. When it is starting it does detect it, but after it enters Windows it doesn t even show up on the Device Manager. Actions taken: Restore...
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected hope this helps don
Mar 13, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Optiarc DVD RW AD-7201S5 drive does not read lightscribe discs
get a new DVD drive, up grade.
VISTA OR W 7 IT IS.
the problems
HP a6642p (SUPER OLD DESKTOP)
CIRCA 2010.. ?
does device manager show, its OK?
HAVE you gone to HP.com and loaded the drivers for this yet?
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-a6600-desktop-pc-series/3793920/model/3825363
Apr 05, 2017 | HP LightScribe dvd640i (DVD640I)...
TSSTcorp CD/DVDW TS-L632D ata dvd drive doesn't burn!!! Vista HP
Most of the time MEMOREX brand is not compatible with HP.
Try a diffrent brand and check if it works.
Jun 05, 2010 | HP Computers & Internet
Can't access CD
If you mean the drive won't open then
Turn off computer
Locate a small hole in DVD drive lid.
Carefully insert a straightened paper clip.
Gently push & the lid should pop out.
Then you can open the drive & remove the CD
Restart the computer and see if it opens normally and reads dvd's now.
If you mean Windows won't read it then the drivers may need re-installing. Check in hardware manager to see if Windows recognizes it or shows an error for it.
May 17, 2010 | HP Compaq nx9010
HP Compaq notebook with a philips dvd-ram won't read
If you can see the CD Drive icon in My computer, it shows that at least Windows recognises the drive. If you are unable to see the drive listed in explorer (not the cd name but the actual drive icon), then please post a reply.
Other than that, you are describing what I think may be a faulty drive. If you open the case, check to see if the drive cable is in good contact with the connector and motherboard.
Feb 10, 2010 | HP Compaq Presario V6000T Notebook
Driver for HP DVD 640
HI, DO YOU HAVE A PROBLEM ON YOU DVD UNIT. WILL NOT RECOGNIZE DC. CD DRIVE PLAYER WORK WITH GENERIC DRIVER LIKE SONIC OR NERO SOFTWARES, OR WITH OUT DRIVER. IF YOUR DC DOES NOT WORK IT IS THE UNIT HAVE PROBLEM YOU HAVE TO BUY DISC CLEANER AT RADIO SHOCK STORE OR TARGET, WALLMART, OR K MART AND CLEANING MIGHT WORK. HOPE THIS WILL HELP.
Aug 13, 2009 | HP Media Center m7250n (ED842AA) PC...
CD DVD drives
try antoher cd-rom to see whether it's the optical drive or the pc>>>
May 25, 2009 | Tablets & eReaders
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
