PC shuts down when I select restart
I am having a problem with my PC shutting down when I select restart. To complicate things more it is only in the administrator profile. In the "limited user" profile everything works as expected.
Any advice would be greatly appreciated.
Thanks,
Brett
  • Anonymous Jan 19, 2009
    i have problem when updating bios for my toshiba notebooks , its satelite a100. When i finish updating bios, it ask for restart the system, but when i restart the system..the bios wont read anymore, i cant even enter F2 for setup. Any help please ?
  • 3,940 Answers
Here are a couple things you can try.
Edit the MSCONFIG Startup tab and Services Tab. Disable the entire startup tab, and HIDE ALL MICROSOFT SERVICES on the Services tab, then uncheck the rest. Reboot, then try a restart. If the problem goes away, then start adding items back one at a time till you identify the item causing the issue.
Updating the BIOS and Video driver are usually helpful.
You can also create a new profile with Admin rights and see if it works normally. Often, a profile will develop issues that are usually easier resolved by just creating a new profile, then moving data files to the new profile. (Never delete the old profile till you are absolutely sure there is nothing left in the profile you need.)
Posted on May 16, 2008
Acer Aspire 7560 wont restart
Before shutting down your system click on any programs still running and shut them down. This will cut the time for normal shut down to take place.
You could also run a hard drive diagnostic to see if it has any errors. There might be some if you don't let the computer shut down itself. Restarting can also cause the programs to become corrupt, if they didn't shut down right. Running a defrag on the drive will also help it shut down quicker.
Look on the net also for information on getting your PC to shut down quicker.
Oct 18, 2014 | Acer Aspire Computers & Internet
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
Comouter shuts down but then restarts same thing happens when i put the power plug in
Hello, that commonly happens when you have a bad motherboard. As long as it does not load the desktop or operating system, then the motherboard is dead. What happened most recently? Did you shut down improperly?
Thanks for using FixYa!
Jul 08, 2011 | IBM Computers & Internet
When I shut down it reemained with shutting Down
No problem, possibly due to null pointer allocation to shutdown thread. Just switch the notebook off using the power button, restart & select start windows normally.
Apr 17, 2010 | HP Compaq 6820s Notebook PC - Intel Core 2...
It went asleep and won't wake up. i have to manually shut it down and reboot...
Hello definedeclin,
Try pressing the <Ctrl> + <Alt> + <Del> keys together.
If that doesn't work then the Asus Eee PC 900 user manual has this information:
Click 'Instant Shutdown' and select an action from the dialog box. You can activate the task manager, put the system in standby, restart or shut down the system.
Here's a link to download the ... user manual (zip file):
http://filestorage.gatzet.com/download.php?file=35dfc283acbdab258c20b25b2438d61e
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 06, 2010 | ASUS Eee PC 900 Notebook
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
Cubase shuts down every time I try to process a recorded file
Hi Melimiti,
You are not the only one with this problem. Cubase is quite a complicate software. If reinstalling does not help we need to have a CLEAN Install on a new OS. If the problem still persist contact the vendor for the product exchange.
Jan 22, 2009 | Steinberg Cubase Recording Software...
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Shuts down, then restarts itself
That can be caused by a number of things , your best bet is to take a look @ this guide...since there are so many things it could be , this breaks it down to make it easier to figure out where it is coming from:
http://www.aumha.org/win4/a/shtdwnse.php
Hope that helps you out!
Oct 07, 2008 | E-Machines etower 500i PC Desktop
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
