Question about HP PSC 1315 All-In-One InkJet Printer
Copier feature (Black or Color) only produces a Black page
All of a sudden the Copier features both Color or Black only prints out a black page.
To be clear printing from the computer works fine, it appears to be an issue with the copier features.
Have tried many different things like:
1. Unplugged, waited 5 minutes and plugged back in
2. Tried quick copying (draft quality) by holding down the Scan button while pressing the Black copy button
3. Tried doing a Color copy
4. Finally I tried pulling the Black cartridge out and put back in
All of these things produce a page with nothing but black ink.
Assumptions, the cover is down while copying.
Any ideas?
Thank you in advance
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
Posted on May 28, 2008
The printer will not switch from color to black cartridge.
Not sure what model Canon you have, but to select BLACK INK ONLY printing, try the Maintenance page in Printer properties. Some models don't have this feature.
Aug 17, 2014 | Canon PIXMA Office Equipment & Supplies
Problems with greyscale printing as colour on the Canon CLC3220
From whatever software you are printing, you will need to select the properties or features. In Pagemaker, it was features, but most other programs I now see it under properties for the 3220 on the print screen. You will need to find where it gives you the options for color. They should be color, greyscale or black & white. The default is generally color. Generally the 3220 will know if it is not a color document and print the black and white as a greyscale, but sometimes you have to force it.
If you are printing crop marks and color bars, then your document is recognized as color even though it may not be.
Finally, some programs use a black that is actuall 100% of CMY & K. If you are using InDesign and select registration as your black, instead of the plain black, then you document is recognized as color.
The same holds true if you select a pantone grey which is created from several colors. So also make sure that your document is truly greyscale and or that you tell the copier to print in greyscale.
Jun 16, 2009 | Canon Office Equipment & Supplies
Hp 2600n will not accept print jobs. Color cartridges show empty. black shows half full. Printing of a test page produces a great test page quality
I have two problems. Either it won't accept a print job or when it is printing it stops when it is going through the job intermittently. Like for an hour it won't continue then all of a sudden it prints one page then a half hour later another page etc. It is so frustrating.
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
Copying feature - HP PSC 1610
The light source has failed thus the original is not being illuminated.
The copier thinks you are copying a black piece of paper.
Printing from the PC does not require any light source, therefore printing is not affected.
Check your manual to see if it mentions a replacement routine; if not, and if it is no longer under warranty, you are maybe stuck with tossing it or taking to your friendly neighborhood techie who is trying to pay his rent.
May 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
Setting copier to default to black
in standard mode set the mode to black then
Press the * key with the circle around
Then select copier features
Then scroll through the pages and select standard mode
Then press STORE
If you require further assistance please get back to me
Thank You
May 07, 2008 | Canon imageRunner C3100 Copier
Enquiry for best latest machine
The 856o is solid ink printer. DN is the duplex version of the 8560. Price should be less then $900.
All print features are available on it. The hard drive is optional.
  • Rich, vibrant colors on everything from cover-weight stock to recycled paper
  • Adobe PostScript 3 and automatic color enhancement tools ensure reliable and accurate prints learn about Xerox Color Correction (PDF)
  • 2400 FinePoint™ print resolution produces incredible detail and halftones you'll be proud to share
  • Consistent, vivid color from the first page to the last
collapse_off.gif more features
  • No penalty for color because the Phaser 8560 prints black-and-white and color at the same fast speed
  • High monthly duty cycle of up to 85,000 images means you'll get a reliable color printer that will last for many years to come
Features that Enhance Ease-of-use
  • Easy to install on your network with only a few clicks See how easy it is to install
  • No toner cartridges! Just drop the no-mess ink sticks into the Phaser 8560's shape-coded slots, close the cover and you're done
  • Instant on-screen alert notification and help when a print job needs attention thanks to Xerox PrintingScout™ technology
  • Access device and job status as well as accounting information from your computer via the Xerox CentreWare® IS Embedded Web Server
  • Prints are secure with Saved Print feature, which won't print your job until you enter your PIN on the front panel (requires hard drive)
  • Electronically "shreds" data stored on the hard drive after every job or on request (requires hard drive)
  • Real-time paper tray status on your desktop shows all available media types and sizes
  • Up to four paper trays can a hold a variety of media types and sizes
  • Automated online troubleshooting with PhaserSMART™ gets you back to work fast
  • Booklet printing feature automatically arranges your document so you can easily fold and staple it into a booklet (requires two-sided printing)
  • Job completion notification lets you know when your print job is finished
  • Run Black allows printing to continue in black-and-white if one or more of the color toners are depleted
  • Print With feature prints your current job (such as a cover letter) along with other jobs stored on the printer's hard drive that you specify (such as a brochure or two)
  • Personal Print feature can create your own private mailbox on the printer's hard drive where your processed print jobs are stored for quick printing via the front panel or embedded web server
Software Solutions Digitize . . . Organize . . . Distribute . . . Collaborate
With digital documents, you can easily create, search, re-use, and build upon your documents. Maximize your hardware investments with innovative software solutions from Xerox and Xerox Business Partners:
  • Contain costs
  • Share knowledge
  • Accelerate workflow
  • Integrate paper and electronic documents
  • Manage and distribute documents effectively
> Show me the Software Solutions
Pricing Details Prices do not include applicable taxes, shipping, or handling charges and are subject to change without notice. Products are available to qualified business customers installing in the US; subject to applicable terms and conditions, and may be either Newly Manufactured, Factory Produced New Model or Remanufactured; which have been produced to a Xerox pre-determined standard and may contain both new components and recycled components that are reconditioned.
1 Average standard pages. Average Continuous Composite CMY Yield in accordance with ISO/IEC 24711. Yield will vary based on image, area coverage and print mode. Read our Consumable yields guide (PDF) for more information.
2 Approximate pages. Declared Yield on Drums based on an average job size of 3 pages A4/letter size. Declared Yield on Fusers based on A4/letter size 20 lb (75 gsm) pages. Drum and Fuser Yields will vary based on job run length, media type, size, weight, orientation, and usage patterns. Read our Consumable yields guide (PDF) for more information.
Mar 07, 2008 | Xerox Phaser 8560DN Laser Printer
HP PSC 1315 All-In-One InkJet Printer Logo
152 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
