Question about Health & Beauty
I have a norelco 9160 xl Need to know which direction the battery goes on to the printed circuit board
  • Health & Beauty Master
  • 1,600 Answers
Positive end goes toward the top of the shaver.
You will find the correct battery at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-liion-battery-cell-for-select-models-p-380.html
Posted on Sep 12, 2010
I need to change the battery in a norelco 7864 xl, how to do it?
You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Mar 13, 2011 | Norelco Health & Beauty
Need instruction on how to replace battery in norelco xl 8825
You will find the correct battery type for model 8825XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 06, 2011 | Norelco Spectra 8825 XL Electric Shaver
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
I NEED HELP REPLACING THE NI-CAD BATTERIES ON MY SPECTRA 8865 XL
You will find the correct battery type for model 8865XL at shaveroutlet.com. See link below.
Jan 12, 2011 | Norelco Health & Beauty
How do I change the batteries in my Norelco 3805 XL rechargable shaver?
You will find the correct battery type for model 3805XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the 4 screws. You may need to extend the long hair trimmer to get to two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Nov 22, 2010 | Norelco 3805 XL Electric Shaver
How do you change the batteries in the Norelco 5801 xl or can I get a manual for the shaver
Start by removing the two screws on the back and remove the back cover. You will then be able to see the batteries. They are soldered to the back side of the circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries for model 5801XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
If you are not able to do this yourself, shaveroutlet.com can do it for you. See information link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Apr 29, 2010 | Norelco Reflex 5801 XL Electric Shaver
My razor appears to have died even though the LED
Usually the batteries last only a few years before needing replacement. Rechargeable batteries are good for only so many cycles so you've done well to go 8 years. You can replace the batteries if you're handy with a soldering iron - I've done it many times. However, with 8 years on the clock you'll probably want to replace the blades too. The batteries are about $10 for the pair (AA rechargeables with solder tabs) and the blade set is about $30 so you're approaching the cost of a new shaver already. Here's a link - you'll need two.
http://www.zbattery.com/NiCad-AA-1000mAh-Rechargeable-Battery-with-Solder-Tabs
Apr 18, 2010 | Norelco SmartTouch 9160XL Electric Shaver
How to replace battery in Norelco 6867xl
You will need to remove the two screws on the back to remove the back cover. Inside, you will first need to remove the two white plastic pieces that the screws you just removed screw into. The larger one snaps in and will have to be popped out from the bottom on each side. The other one has two screws that need to be removed. Once these are removed, you will be able to better access the batteries.
The batteries are soldered to the circuit board but instead of unsoldering them, I suggest carefully breaking the solder tabs off of the ends of the batteries. This leaves the old tabs still attached to the circuit board and you can them simply solder the new batteries to those old tabs. This prevents you from having to put a hot soldering iron directly to the circuit board.
You will find batteries for your model at shaveroutlet.com. See link below.
Feb 10, 2010 | Norelco Quadra 6867 XL Electric Shaver
Norelco 9160 XL
two rotors are broken
Jul 28, 2008 | Norelco Health & Beauty
Norelco 3805 XL Battery Replacement
I was able to open mine with a 2.4mm slotted screwdriver from one of those mini-screwdriver sets you can get at the store for a couple of bucks. Be aware that the batteries are soldered to the circuit board in this particular razor.
Jul 19, 2008 | Norelco 3805 XL Electric Shaver
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
