Question about Remington Polesaw Wizard
Remington mighty mite chain saw
The oiler on my saw appears to be plugged up. I have been told that the oiler is powered by compression. How do I unplug the compression line?
Thanks in advance.
Wayne
  • Anonymous Mar 24, 2014
    owners manual
  • 211 Answers
Hi Wayne
Oiling has nothing to do with compression.It has conection only with engine rotation(rpm).More rpm results more oil and viceverse.Check the oil filter,the oil line,the holes from the bar,the oiler,the wormgear and the oil hose.
wish you all the best savumihai71
Posted on Dec 02, 2008
Remington manuals
For an electric saw, just add oil to the chain oiler, plug it in, and cut away. Do not put any body parts in contact with any of the moving parts of the saw.
Sep 02, 2014 | Remington 10" Electric Pole Saw Chain...
3.0 Peak HP 16'/41 cm remington
You might actually have the chain too tight. With the saw off you should be able to lift the chain until the gear tooth (tooth on inside of chain) almost lifts out of the chain bar.
I've never used an electric chain saw but if it has a chain oiler you should also check your chain oiler to make sure you're getting enough oil on the chain, if you run the saw with the chain aim at a clean surface you should see oil on the surface almost immediately.
May 26, 2010 | Remington Electric Chain Saw
Oiling the chain
I happen to have an IPL for your saw. This may be helpful Colin.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 09, 2010 | Remington Electric Chain Saw
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Remington Mighty Mite gas engined chain saw . How can I replace the stud for the guide bar ? The stud is stripped and I have attempted to unscrew it without success using vice grips. It turns but appears...
Was this saw manufactured in the 70s? If yes what are the odds anyone can help you? arboristsite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of chainsaw enthusiasts (free to join) that restore old saws. there is a thread that discusses your saw.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf
You might find some pointers here as well
If its mine and I'm serious about repairing I'd find a machine shop.
Lou
Sep 18, 2009 | Remington Garden
Guide bar nut loose (stripped stud). How do I replace the stud ? It does not seem to unscrew ! Remington Mighty Mite
I hope the nut is stripped and the stud is OK. Try to gently wedge something below the nut and with a socket attempt to slowly unscrew it.
Remington IPLs can be found here:
Remington.com
http://www.remingtonpowertools.com/find_manual.cgi
They do not use model names. Under "Products" click "Chain Saws"; find an image matching your model and click it. Some list a manual that includes an IPL some do not. If no IPL is listed the only place to get help is the "Repair Center" nearest you for parts. I doubt a bad stud can economically be replaced.
If the stud is still good NAPA Auto Parts can assist you to find a replacement nut. HTH
Lou
Sep 17, 2009 | Remington Electric Chain Saw
I HAVE A REMINGTON 400 MIGHTY MITE...MY PROBLEM
Joe you are weak! While we are not calling you a sissy girl, we do wonder. You need to build up your arms. Try lifting weight for about a month before you try to start the engine again. Stay out of dark alleys until you do. We will be watching.
Sep 10, 2009 | Remington Garden
Remington Polesaw Wizard Logo
644 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
