Question about Philips HSB3280
No sound coming from sound bar only from sub-woofer but very low
5 Suggested Answers
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
  • 38 Answers
SOURCE: Sub Woofer Stopped working
May be when you turned it, some of the wire connection inside must have got broken or the magnets must have got displaced or somewhere connection would have got loosen check all of this.
Posted on Jul 17, 2008
  • 71 Answers
SOURCE: HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Posted on Jun 24, 2009
SOURCE: I have a sound bar
you ever found a sloution to this?
i have the same need (for a new subwoofer for this model)
Posted on Sep 14, 2011
What is a sound bar woofer and function
A woofer is a device that producers low frequency bass sounds. Often in a form of Sub Woofer. Bass sounds are not directional. So once set up it will give the rumble and vibration needed to the sound system.
Dec 27, 2016 | Audio Players & Recorders
Samsung sub woofer # ps-wx810 will not connect to sound bar # ht-x810
Smash away. I don't think you can connect a wireless piece to a sound bar. This may be out of my wheelhouse, but I don't think so.
Feb 22, 2016 | Samsung HW-E450C 40" AirTrack Sound Bar...
Hooked up HW-D450 sound bar to Samsung UN40D6000SF TV with low output from sub woofer
Have you adjusted the subwoofer level? there should be buttons on the remote to adjust this level. Also, make sure you are not in a 'night' surround mode - this drops subwoofer levels a lot
Apr 08, 2015 | Samsung HW-D450 Sound Bar
Sub woofer wont pair, brand new NB3740 LG Sound Bar
smart electronics sometimes aren't as smart as we wish for eh
Feb 23, 2015 | LG Audio Players & Recorders
Trying to find out what type of sound bar that will work with my tv
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
Feb 26, 2013 | Hisense Televison & Video
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
Alesis M1 active 620 woofer problem
There clearly is a fault in the sub's amp section. It's probably the main part that does most of the work. It will need to be replaced.
Mar 07, 2017 | Alesis M1-Active MkII Main / Stereo...
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
Philips HSB3280 Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
