I can't get the pip screen to work. I have a splitter from the wall cable, one side to the comcast HD box, the other to the tv. Nothing comes up in the pip screen
  • 201 Answers
You might look to see if there is a pip option in the tv menu its possible that you may have to let the tv know which input will be used for pip
Posted on Sep 12, 2010
My Comcast remote quit working with the cable box. The guide wont come up any more and my hd doesn't look like hd....just standard. I went to look in the back and I thought I had hd but I only have coax....
You need an hd cable between your cable box and tv. They don't provide them for free. Once you plug in your hdmi cable to the tv, change its input to the hdmi port you just plugged into. The guide is updated by the cable system on their internet but over the coax. Give it time, it should come back. If not, reset the cable box by unplugging itfrom the wall power, wait 5 seconds, plug it back in. It should come back.
Sep 02, 2017 | Televison & Video
How do you get the picture in picture to work? What two sources can you use, a cable box and what?
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Let's say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected that's not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables; these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by their Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and + buttons located near the bottom of the remote. You can swap picture in the Main and Sub screens using the swap button and swap which screen will sound off its audio by using the AUDIO button. You might notice an X next to some of the selections in the INPUT and PIP INPUT screens when you have PIP activated. That means that input selection is unavailable and cannot be used. For example, if you have the input TV selected on your main screen then if you press the PIP INPUT button and bring up that input menu you will see X's next to the TV and AV selections. The X's mean that when you have TV on the main screen you won't be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them.
Sep 14, 2011 | Vizio VF550M 55 in. LCD HDTV
How too make work the small pip on a 52" LCD HD tv samsung
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Dec 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
No cable outlet for 2nd hd tv. Connecting to primary tv? Comcas
You are at the mercy of the cable company unless you can get an antenna to work.
Dec 02, 2009 | Televison & Video
Splitter side of Comcast cable signal unusable. Converter box OK
DTR's are available everywhere. You can also go online and purchase one if your local stores do not have. Also, keep in mind that the splitter you use must comply with the signals unless you use the Video output of DTR.
Jul 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture-In-Picture does not work (32" LG LCD)
my friend told me that if Tv is purchased from Canada will not work in Saudi Arabia but why?
Mar 18, 2009 | LG 32LG30 32 in. LCD HDTV
Can't get PIP to work on my Samsung LCD 46"
its talking about the analog tuner in your tv. split the cable before it hits the box plug the cable strait into your tv if there is more than one coax connector on your tv you will need a second two way splitter run one into ant a and one into ant b yo will not be able to use pip and hd at same time you can only do pip with the analog tuners built into you tv
Mar 17, 2009 | Zenith Z36X31D TV
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
