Question about Whirlpool Refrigerators
Hi. I have a model ED5NHGXR001 Whirlpool. Ser. # ST1045037. The motor is making a very loud, straining, grinding sound. It is not totally continuous, but it started intermittently yesterday (about 30 minutes at a time for a couple of times). It is now doing it today. It has not stopped so far (about 45 minutes). The refrigerator is still cold and seems to be working. I have tried unplugging and plugging back in, but the sound continues. What do you think needs to be done?
  • 10,515 Answers
Do you have any idea from where this noise is coming from?
Either the motherboard has a chattering relay or the compressor relay/overload is chattering. Your going to have to pull the panel off on the lower back and listen to the compressor relay and the mother board to figure which one it is.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Washer got very loud during spin cycle this continued and then when its spins it sound like the tub is grinding against something and also squeeling noise during washing.. and spinning.
HI,
This sounds like a leak under the unit and above the motor. I would suggest tipping the unit back, look unit the washer for milking brown residue on the cabinet and the motor area. If present you will need a new outer tub and this won't repair will not be cheap. I am sure this answer is not what you want to hear. If no residue, I would look into the pumps as you can have a foreign objects inside them and cause a-lot of noise during operation. But the only way to make sure if to look.
Hope for the best...
Jul 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I HAVE A GE GAS DRYER MODEL DDG5980VALWH SER. 3F302890G. WHEN THE DRUM TURNS IT MAKE A THUMPING SOUND,,NOT REAL LOUD. MORE OF A THUMP THEN A SQUEAK.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | GE Dryers
Won't spin and loud noise
Kenmore washers could hold a few problems. First, without a model number you don't know who makes it. See, Kenmore does not make washers, they have someone else make them such as Whirlpool or Frigidaire. More that likely you have a Whirlpool (which is a good thing). What you are probably hearing is the coupler of the machine broken. A coupler is what replaced a belt in the newer machines. This piece is installed in between the motor and transmission. If it breaks it makes a loud rattle/grind sound. It is possible that the transmission is also the culprit. However, this noise is entirely different. A bad transmission generally makes a loud screech noise. If this does not help, please post a model number of the washer and I will gladly further assist you :)
May 28, 2010 | Kenmore Washing Machines
Grinding sounds
Grinding sounds that last for longer than 3 minutes at a time are usually an indication of something in the wash pump. If the grinding is only for about 2 minutes at a time it would be something related to the drain pump.
It depends on the make and model on how to clean out the pump or drain pump. If you happen to have a tall tub Kitchen Aid, Whirlpool or Kenmore this link has instructions on how to do that.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 01, 2010 | Dishwashers
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Whirlpool washer Loud Grinding sound in spin cycle
HI,YOU MIGHT HAVE EITHER A BROKEN SPIDER THAT IS LOCATED BETWEEN THE IN AND OUTER DRUM OR A BROKEN BEARIG.BEST YOU GET A EXPERT TO HAVE A LOOK AT IT FOR YOU.GOODLUCK.MOHAMED
Sep 10, 2008 | Washing Machines
Whirlpool Dishwasher suddenly making a grinding noise...
Motors for tall tub whorlpools are over two hundred dollars. If its less than a year then its under warranty. You did not indicate model. If you can get back to me I'll look more in to seeing if it is feasable to repair or replace.
Jul 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
