Question about Presto 04820 PopLite Popcorn Maker
We spilled melted butter into the base that holds the kernals. Now we get black smoke when we plug it in. I tried running it on empty for awhile, but the smoke continues. Can we remove the top and clean the inside? Thanks.
    Problem Solver:
  • 10 Answers
You can open it but not from the top. unscrew the bottom and take out the heater and clean out the Popper without using any water or soap just a toothbrush and cloth. it will take more then one clean out to get it to stop smoking (took me 3 times). put it back together place a plate under it to catch butter and run it for 10 min. to get hidden butter to melt and seep out of hidden spaces then repeat cleaning.
Posted on Mar 10, 2011
Heavy black smoke from exhaust during the acceleration
Smoke in the exhaust is a result of either too much gas or something other than gas being burned and there are a couple possibilities of what else could be burning. So there's a chance that either you mixed something in your gas you put in, or your engine is burning oil, you are burning antifreeze, or you're just burning too much gas but the engine wouldn't run very well. You didn't say anything about other issues...like how overall the engine is running but the engine could just need a tune up?
But antifreeze usually burns white so because you said it was black smoke (usually more blue colored when oil is the cause) I don't think it's antifreeze.
Black smoke can appear due to an engine that needs a tune up but it's usually not that noticeable.
The most common reason for heavy smoke coming out the tailpipe is because you're burning oil.
If you find you have to add a lot of oil regularly to the crank case and there are no obvious leaks (look for spills on the pavement where the bike is parked) then you're probably burning that oil and with the smoke you see...that just about nails the cause of the smoke.
How do you fix it? Usually you have to change the rings on the cylinder/s. Cold be one Cylinder or all of them. But generally if you do one cylinder you do them all since while you're doing it...why not do them all?
So based on what you've said...that's the best I can do.
May 10, 2015 | Factory Effex Suzuki GSXR600 750 Lower...
Wow empty and power steering fluid out of my reservoir of my 02 PT Cruiser it spilled all over the top of the engine block where the spark plugs are ..
Flat blade screw driver, and wrap a rag around the tip, stick it down into the sparkplug hole and suck up the fluid. Don't take out the sparkplugs while doing this, just go down the sides. Just wipe up what you can, the rest will burn off. You'll probably see some smoking in there for a bit, but no big deal.
Mar 04, 2015 | 2002 Chrysler PT Cruiser
1983 honda gl 1100 at1000rpm,quit throttle get's black smoke; not much.Sometimes one side sometimes the other side;Runs good from 0 to 70 Today cruising at 70 in 5th; I tried slow acceleration from...
Hi, probably you have a high milleage engine, for what you describe (black smoke) you have a very rich fuel/air mix ,
About it take a wille to lower revs, that's because the valves are note settingg properly. You'll probably need to have them reconditioned .
good luck
Sep 13, 2011 | Honda GL 1100 Gold Wing Motorcycles
The connection on the black compresor melted
too hot because fan not working or coil plugged
Jan 02, 2010 | Refrigerators
A layer of peanut butter (film) on sides of disherwasher
try a product called dishwasher magic. or you can try just useing white vinager and run with nothing in it put in about 2 cups of viniger
Sep 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Apr 10, 2009 | Cuisinart PartyPop Maker Popcorn Maker
B4 blowing plooms of smoke
Assuming that the Smoke is White or Black, You are gonna have to get an Overhaul on that Motor.
Jan 04, 2009 | 2000 Subaru Legacy
Presto 04820 PopLite Popcorn Maker Logo
226 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
