Question about HP Computers & Internet
The issue is coming from a new HP All-In-One Computer. After booting it will operate for a short time (even shorter if you try to run a program or web surf) and shut down, completely unresponsive. I removed the back cover looking for anything out of place. I happened to notice how small the fan was and how close it was to the cover(cover has no vents or openings near the fan). I decided to leave the cover off the back and operate the system and it worked fine for three days but today, as soon as I put the cover back on, it was not long before "splash". Anybody else having problems and, am I on the right track thinking the computer id overheating.
  • 10,515 Answers
Overheating is a common problem with HP computers. Have you checked whether the fans are running at optimum speed or not?
There are some tests that you can do to see if that is the case. If you boot into safe mode (press F8 while the computer is starting and repeatedly press it) you will come to an advanced start up menu. Select safe mode from this and see if it still happens. Safe mode wont load any drivers for things that are not needed. You can download and install almico speedfan and see what the temp of the CPU is doing. (http://www.almico.com/speedfan.php) this will tell you if it is overheating. You can check the control panel, admin tools, event viewer and system logs to look for any errors that might be present. You can take some of the RAM out and see if that is the problem. Last but not least you can reload the entire operating system to see if that helps. These things help narrow down the issues that could be causing the shutdown. If it is overheating then you need to make sure that the fan is running and that the heat vents are clean. If this does not help, you may end up having to remove the case and remove the heatsink and reinstall it making sure that you have a good connection where the heat dissipates from.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Computers & Internet
Tip
Speed up Windows Boot Time
Many people ask about Windows boot times and how to make your boot time shorter. This is a quick tip about how to eliminate some of the unneeded or unnecessary items from your Windows XP/Vista/7 boot time.
First, make sure that you are logged in with Administrator privileges.
Next, Click the Start Button (Windows logo button in Vista and 7) and then click Run. (In Vista and 7 you can just type into the search box under the Start button). Type "msconfig" (without the quote marks) and then click OK or press enter.
In the System Configuration Utility, click the Startup Tab and deselect all of the items. In the Services tab, check the box for Hide all Microsoft Services and then disable all the other items.
Now, you will need to reboot your computer after applying those changes and time the boot up. If the time is dramatically faster, then it is likely that one or more of the items in the Startup Utility are causing the lag in boot time.
Go back into MSCONFIG and go to the services tab. Re-Check a few items, apply the settings and reboot. MAKE SURE TO WRITE DOWN WHICH ITEMS YOU'VE RE-CHECKED. Now time the boot up process again. Continue this process of re-booting, timing, going into msconfig and checking a few items back, and rebooting and timing until you find the items that add significant time to your boot up process.
Once you've found those items that are adding time to your boot time, you will need to determine if the item is one you can leave unchecked - or if it is something that you may need to run during startup. If it is a critical program, you can try to get it to boot quicker by reinstalling the program or seeing if an update to the program will fix the issue.
Hope this information is useful!
on Nov 20, 2011 | Microsoft Computers & Internet
My HP laptop (Pavilion) is running very slow. I'm afraid to download the ''TV Specials'' we see advertised. Thx, Ray
download 'ccleaner' from filehippo.com & run it & remember when u run it, only check the temporary files,recycle bin,recent documents....
this might speed up ur notebook...
If you are using XP or Vista, you have this. You can access the boot menu by loading your MSCONFIG. During the boot up your computer issues a time out to find new hardware and software. You can short this time to boost your startup speed.
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility, click either BOOT tab.
5. In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Jul 09, 2010 | HP Pavilion dv6000z Notebook
I just bought a new HP Pavillion p6320f. Several times after downloading microsoft updates and restarting, the computer would simply not go to the desktop after showing the Starting Windows screen. Even...
My advice would be since you been onto HP tech, is either get hold of your copy of the operating system cd, and boot from CD and enter the windows CD key which should be on a sticker somewhere, and start a fresh without any of the so called bloatware that comes preinstalled on the machine, which may be causing problems with long boot up times and causing windows updates problems. If you can't get hold of the CD, of the operating system cd or wasn't supplied one, ring HP and they may supply you with one, but big companies don't like to hand them out. But worth a try. Alternativaly, get hold of a copy from someone else, but use your Windows licence key to install, otherwise it's illegal. Then you would have to go to HP website and seek out drivers for your system, look for support/drivers and you should be able to put you PC model number in and get to the page with the drivers you need.
Alternatively, remove all HP related software from add/remove programs within the control panel, and anything else that was preinstalled that you dont use. and see if that resolves the problem.
But I'd go for the first option personally as you wont have all the HP garbage installed, but just a fresh installation, and hopefully a speedy top notch pc.
Note... Make factory restore recovery CD's before doing any of this, should be an option in the start menu somewhere check your manual/user guide. THIS IS IMPORTANT just in case you send it back.
Jan 26, 2010 | Microsoft Computers & Internet
Every time I boot the computer, a windoow comes it says you are t
there is a program you have deleted trying to startup in the background.
An easy fix is to START>RUN> type msconfig
Click on the STARTUP tab.... and UN-Check everything except Antivirus software.
Click OK, and re-boot PC.
Thanks for using FixYa - a FixYa rating is appreciated!
Feb 24, 2009 | Computers & Internet
Won't complete booting
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Jan 18, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
Computers & Internet Logo
21 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
