Question about Brother XL-3500
I keep breaking the needle because when the presser foot is down it hits the plate on the bottom of the machine
    Genius:
  • 1,788 Answers
Refer to your manual, it gives all sorts of reasons for the needle to break, wrong bobbin size, scratched plate, needle being inserted wrong. If, you do not have your manual go online to
brother-usa.com and download one for free.
Posted on Sep 11, 2010
Keep breaking needles after putting down presser foot
Sounds like you need the manual. This will give you a lot of basic information on how to use your machine. Please read the book all the way through.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwit24G7z-bSAhWqwFQKHZjPD1YQFggcMAA&url=http%3A%2F%2Fwww.brother-usa.com%2FModelDocuments%2FConsumer%2FUsers%2520Manual%2FUM_XL_2600_2610_3500_3510_EN_206.PDF&usg=AFQjCNGxRYCu023uIgfNhqFvn7XXwkK2CA
Also, check that you are using the proper presser foot for the stitch you have selected, ie do not use a zig-zag stitch with an embroidery presser foot that has only a tiny hole for the needle. Be sure you are installing the needle correctly. If the needle is backward, it could be hitting. When a needle hits something solid, it could knock the machine out of time, requiring a service call. Before running the machine, you can check whether the needle will clear by hand-rotating the handwheel one full cycle. If the needle strikes something, at least you can stop before it breaks or causes further damage.
Mar 21, 2017 | Brother Sewing Machines
Keep breaking needles when i put down presser foot to sew iwant to sew straight stich to hem a curtain
If the needle is hitting something, make sure you have the machine set for straight stitch and the needle is in the center position. If it is still hitting and breaking, then the machine is out of adjustment and needs to be repaired.
Mar 20, 2017 | Sewing Machines
My needle keeps breaking because it's hitting the square part of the presser foot that it goes down into.
If your machine has multiple needle positions, make sure the needle is set in the center position. Also, make sure you are using a zig-zag presser foot where the opening is wide enough to accommodate an off-center needle or to make decorative stitching. If you are using a straight-stitch foot, then the foot will have only a small circular hole in the center and the machine must be set for straight-stitch only.
It the needle still hits, then the needle bar may be off-kilter. Take it for service.
Look at the Different Types of Sewing Machine Feet
Mar 18, 2017 | Sewing Machines
Why do needles keep breaking?
Just guessing here. Is the needle hitting the presser foot? If so, it could be the wrong presser foot for your machine (especially if it is not attaching properly), could be the wrong needle for the machine or is installed incorrectly, could be the needle bar is not centered, or the needle position setting could be off to one side or the other rather than in the middle. Hard to diagnose without more information.
Apr 15, 2016 | Sewing Machines
When I sew silk or fine fabric the thread breaks and the fabric bunches up, what am I doing wrong, I first had the A foot and changed to B, changed the needle and still the problem persists
Check to be sure you are using needles and thread that are compatible with the fabric. Generally, finer threads will work better on fine fabrics along with a smaller needle. Be sure to change needles frequently as dull, bent, or nicked needles will cause very frustrating issues.
All About Needles
Remove the thread completely from the machine. RAISE the presser foot and rethread from the beginning, making sure the thread path is correct.
Some machines have a presser foot pressure adjustment (consult the owner's manual). Adjusting the pressure that the presser foot applies to the fabric & feed dogs is helpful when sewing especially fine or heavy fabric. Also, when sewing fine fabrics, loosening the tension could be beneficial.
Changing presser feet may also help, ie try using a straight stitch foot vs a presser foot for zig-zag stitching.
Something else you can try is finding a presser foot with a teflon finish or a roller foot that will glide or roll with the fabric through the machine. Even if you can't find a brand name presser foot for your particular machine, an adapter shank can probably be found that would allow you to use snap-on feet of all different designs and uses. Provides a lot of choices for presser feet for less than purchasing a brand-name presser foot. There are snap-on kits available on eBay and other auction sites.
Some machines also can take a straight-stitch needle plate--usually an additional accessory that can be purchased. The hole where the needle penetrates the needle plate to access the bobbin thread is actually a small round hole. With a zig-zag needle plate, the hole the needle penetrates is a wide rectangular hole that can allow fine fabrics to be pulled down through the hole. Zig-zag capable machines usually have a zig-zag needle plate as standard.
Feb 22, 2016 | Sewing Machines
Broken needle
ck the alignment of the foot plate (under presser foot) if needle rubs this plate it will break every time
Jan 21, 2016 | Sewing Machines
How to change sewing for different thicknesses
First, you will need to select a brand new needle of the type suitable for your fabric. Select a proper thread weight and type for your needle and fabric.
Select the proper presser foot for your project/fabric. On some fabrics, you may even want to use a straight stitch needle plate to prevent the fabric from going down the needle hole.
You will want to adjust the upper tension so that the upper and bobbin threads meet in the middle of the fabric.
Also, probably want to adjust the presser foot pressure so that the presser foot presses harder or lighter (depending on the fabric) so the fabric will feed through evenly, ie both the top and bottom fabrics move together at the same rate. Hint: if it is really thick, like sewing a quilt with batting, a walking foot may be helpful.
Be sure to test on scrap fabric from your project before beginning sewing your project together.
All About Needles
Why is there an extra needle plate supplied with my machine Brother straight stitch plate and presser foot cannot be used with zig-zag or decorative stitch or you will surely break your needle and possible knock the machine out of time!
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwib0Z_YrrbJAhUBUGMKHc6OBhAQFggeMAA&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q&cad=rja adjusting tension
Adjusting Sewing Machine Tension to Prevent Problems
http://makeitsew.biz/presser-foot-pressure
Adjusting the presser foot pressure on your sewing machine
Nov 29, 2015 | Sewing Machines
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
New Home My Lock 134D Serger. The right needles keeps breaking. Yesterday I realize it is hitting the pressure foot. I have changed out the needle (size 14) about 7 or 8 times now. I have adjusted the...
check to see if the presser foot is loose
check to see if the needle is in backwards
if the presser foot is tight & needle is not in backwards then it could be a timming problem, since you said the needle is hitting the presser foot
please rate this with the thumbs in upper right hand corner
Aug 08, 2010 | Janome MyLock 634D Mechanical Sewing...
What foot do I use with the twin needle?
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Feb 09, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother XL-3500 Logo
133 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
