Question about Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack
Problem with Raymarine st 60002. Was working fine but now when you tell it to go to cursor it does a 180 degree turn. For some reason it thinks it is facing the wrong way.
2 Suggested Answers
  • 38 Answers
SOURCE: Remote on my Raymarine ST 4000 stopped working -
If the remote is the wire type ,check continuity of the wires in the cable ,specially at the bending places where the cable comes out of the connector and the control unit.,Cut away internally broken part of the cable,and solder again respecting the coulours ,or change the whole cable respecting the connections.
Posted on Jun 21, 2010
Need to know rocker torque on 3.5v6 and all so i think i know but i need you to tell me,i torqued 20ftlbs-40ftlbs then a 140 degrees what does that mean?a 140 degree turn?
A circle is 360 degrees. If you moved the pointer on a clock from '12' through 360 degrees, the pointer would be back at 12 - having travelled 360 degrees in a complete circle.
Half a circle is 180 degrees - if you moved the clock pointer from '12' through 180 degrees it would point at '6'.
A 140 degree turn just means that you turn the bolt clockwise through 140 degrees. Put a small mark on the top of the bolt - at the 12 o'clock position then turn the bolt until the mark is at about where '5' would be on a clock face.
Apr 20, 2016 | 2006 Chevrolet Impala
Raymarine a50d continuously resetting itself?
If there's a memory card installed for maps, try starting up the unit with it removed. It's possible that the card might be corrupted and stalling the start-up sequence.
May 10, 2014 | Raymarine A50D 5" Fishfinder /...
Beeps continuously
This is almost ALWAYS caused by a poor power connection. Check, lubricate and clean/inspect your power cables. I have seen poor solder connections or corrosion prevent the ST 2000+ from getting the horsepower it needs to operate properly.
Hope this helps.
-Steve
Apr 23, 2014 | Raymarine ST2000 Tiller Pilot A12005
St4000 auto pilot makes 180 degree turn for no good reasonn
It has been a while since I set up my auto pilot, but Raymarine has a very good set of on-line manuals and it would be a good idea to go through the setup procedure again. There is a sensitivity setting that adjusts the responsiveness of the AP in relation to changes in the helm. If it is set too sensitive, the AP will make big changes when the helm slightly moves.
Jan 09, 2014 | Raymarine Boating
My husbands needs an onwers manual for Craftsman 180 degree precision laser level with laser trac mode No. 320.48253 to see what an item in there does?
I think the reason we can't find the manual for 320.48253 is because Ryobi took Craftsman to court claiming patent infringement because of one of the bases included in the Craftsman kit.The suction cup wall hanging base was to similiar to Ryobi's Airgrip base so Craftsman agreed to not sell in the USA no more.
Jan 19, 2013 | Craftsman Laser Level - Sears 180 Degree...
Raymarine st 1000 displays 1000 (flashing and beeps) and the actuating rod will not move
Have the same problem, sick and tired of it. It is 18 month old, had repaired once 2 months ago by raymarine, some soldered joints came undone on the board, not working again! Used it 4 times since new out of probably 20 attempts. Every time I try to use some new problem raises. Possibly just my luck. Just ordered a new Navico st 32 heard it is better unit.
Jun 10, 2012 | Raymarine St1000 Plus Tiller Pilot
Remote on my Raymarine ST 4000 stopped working - how do i troubleshoot problem?
Jun 06, 2010 | Raymarine St 4000 Wheel Drive E12093
We rekeyed our deadbolt and for some reason the key does not work and we can't unlock the door (from outside)..help!
The lock tang (the item between the two lock parts inside the door) has been turn 180 degree out of position. Take the lock off, turn tang 180 degrees, reassamble, and it should work like new.
Sep 01, 2009 | Weiser Lock Locks & Locksmithing
i had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
Jul 24, 2008 | Raymarine St 4000 Wheel Drive E12093
Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack Logo
99 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
