Question about Canon ZR700 Mini DV Digital Camcorder
Grey Bars appear on video playback
Stationary grey bars are appearing on the video playback, no matter which tape I use. These grey bars do not appear during video recording
  • Canon Master
  • 5,568 Answers
The monitor you view while recording does not read from the tape where the problem is located, that's why you are not seeing them during recording.
Since they are not visible while recording, the video section is healthy, only the recording is faulty and it is unlikely you can do anything at home to correct it.
This may be a common problem and perhaps Canon is familiar with it.
I recommend you call their service line directly:
email: https://www.usa.canon.com/consumer/controller?act=SupportMailerAct&fcategoryid=227&modelid=12812
Phone: In the US: 1 (800) 828-4040
Posted on May 14, 2008
Grey bars on screen
You nead a head cleaner mini dv for your camera if its 6 mm.
Feb 11, 2014 | Sony Handycam DCR-TRV11 Mini DV Digital...
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Dec 09, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Horizontal grey bars across screen.
This sounds like it is the Tape recording function that is at fault. Unfortunately, it's also one of the most difficult to correct without a scope and test jig.
However,
If it is more than 5 years old, it may be suffering from component failure.
In particular the Electrolytic capacitors in these small cams seem to fail first due to temperature and humidity changes. They can leak, dry up or corrode, so it may be worth looking inside at the control boards to spot any physical signs of deterioration.
This shows typical surface mount capacitors - silver cylinders with black segment denoting negative -
Sep 08, 2009 | Canon ZR200 Mini DV Digital Camcorder
Bars across picture when replaying tapes.
The tapes were recorded in LP mode and the replay is set to SP mode. Switch from "EASY" to "P" and replay and you should be OK
Apr 27, 2009 | Canon MV800i Mini DV Digital Camcorder
Bars on tape playback
I would first try testing it out with Sony tapes first. If the problem persist, then it needs to go in for repair.
Feb 02, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
I have a sony handycam - dcr-pc109e. When viewing a tape, there are grey horizontal bars across th screen that have just appeared. I cannot seem to get rid of them. Any ideas please?
Gray horizontal lines appears when video heads in camera got dirty / clogged.
Use good quality video cleaner cassette to clean video heads, problem will resolve.
Dec 16, 2008 | Cameras
Canon ZR200 grey bars
clean the tape heads with a special cleaner cassette
May 21, 2008 | Canon ZR200 Mini DV Digital Camcorder
Playback problem
I've encountered this exact problem a month ago, except cleaning the heads did not fix it. However, I was able to find an alternative solution...
After leaving my camera closed up in a drawer for a few weeks, I decided to take it out and leave it in the sun for 15 minutes, assuming that perhaps the gray bars were a result of moisture damage. The next day (Today, to be exact) I turned my camcorder on, and the gray bars have gone away from playback, as well as the reduced sound quallity it caused.
Apr 20, 2008 | Canon ZR800 Mini DV Digital Camcorder
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
Feb 09, 2008 | Sony Handycam DCR-PC110 Mini DV Digital...
4-5 Grey Lines appearing in the Playback Mode when playing tape
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
Oct 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon ZR700 Mini DV Digital Camcorder Logo
438 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
