Question about Grohe 27.007 FreeHander Shower Head Shower Accessory - Lifetime Satin Nicke
We have a Grohe freehander (27 007) that has been installed and working fine for the last year. Yesterday after turning the water on and lifting the arm, water began to shoot out to the left of the middle nozzle. It appeared that part of the assembly had come out from the base. Similarly next to the middle nozzle there was space (where the water was shooting out). I gave the arm by the base a firm tap with my palm and it went back into place, but when turning the water back on it again expanded away from the base and water came out of the space next to the nozzle. I contacted Grohe and provided a picture. They directed me to the vendor where I purchased it. The satin model has been discontinued so I don't have the option of a replacement. One of the gents at the vendor location mentioned after talking to Grohe tech support that there was an allen screw under the base plate which I've since tightened. It appears to work but I'm hesitant to use the shower. Is there anything else I should try, like replacing O rings or do we have to get a new shower head? The shower was pretty much designed around this fixture and its worked great up until now. Any help would be greatly appreciated. Thanks!
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 34 Answers
SOURCE: Grohe hand held shower head stopped working
This is a simple fix. The tools you need are: cresent wrench. You want to remove the shower hear off of the pipe coming from the wall. On the inside of the end off the shower head there should be a small plastic disk remove it. It will have a series of holes this is called a water saver. The holes get stopped up with minreals take a tooth pick and clean them out. I see this all the time. If that does not work it will be in the valve
Posted on Feb 04, 2009
  • 74 Answers
SOURCE: i have agrohe shower fixture with poor pressure
If the shower head is clogged (even if it it is not I would still do this)
remove the head and soak in coke (yes, it works), CLR, vinegar or bleach and see if you can dissolve the debris. If that is not the culprit, check to see if there is access to a shut-off valve behind or below the shower. It will be inside of the wall and is only acessable through a hole in the wall.
If that is not the case, it is now time to consider replacing the shower body. This is an involved job but something very doable by a competent homeowner.
Hope this helped.
Posted on Apr 16, 2009
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 561 Answers
SOURCE: freehander leaks at shower heads
Hi
Thank you for your query
If you just grab the showerhead with one hand and then unscrew anticlockwise the pipe underneath it should just screw off, once this has been done simply replace the O ring and rescrew
I hope this has been useful
Posted on Mar 15, 2010
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
I have a Grohe Freehander. One of the shower heads has hardly any water coming out. The other shower head has good water pressure. I have sprayed CLR on the shower head but it doesn't appear to have...
Try soaking it in vinegar...this will help break some things that CLR will not. Soak it for five minutes, then rinse, and try again. It will help a lot...rate if it helps!
Oct 05, 2010 | Home
Freehander leaks at shower heads
Hi
Mar 14, 2010 | Grohe 27.007 FreeHander Shower Head Shower...
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
Hi there, I have a 27007 Freehander that was just installed by a plumber. When I turned it on to test, the right hand side of the swing arm, pulled away from the mounting assembley, and water shot up...
Without being ther and seeing I ofcourse can't be sure but based on what you have told me I would lean towards defect. There is no such thing as perfection in any assembly line. It's not ever easy to block water under pressure from coming from a place it was not designed to come from
Feb 08, 2010 | Grohe 27007000 Chrome Freehander...
Hot water pressure is fine, cold water is low.
You may have debris caught in the supply line or the mixing valve. You will need to take the unit apart after you have turned the water off and inspect those parts. Also, some of the new faucets have cut off valves already installed on the faucet, if you do make sure that they are fully open as well.
Mar 31, 2009 | Grohe Plumbing
Grohe 27.007 FreeHander Shower Head Shower Accessory - Lifetime Satin Nicke Logo
100 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
