Question about Toshiba Televison & Video
I have a toshiba 19av505d tv which has been on the wall and now I would like to use the stand. The bit attached to the tv is facing the wrong direction to stand up properly but I cant get it to move. Am I meant to unscrew things?
4 Suggested Answers
  • 34 Answers
SOURCE: taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Posted on Apr 08, 2009
Sparky2012
  • 102 Answers
SOURCE: How do I FIX A TOSHIBA 19AV505D TV TO THE WALL
You need to get a bracket, you can find it At Bestbuy, Walmart, etc, and then follow the intruction that came with the bracket
Posted on Dec 05, 2009
  • 39 Answers
SOURCE: How do you remove the bottom stand from the TV set
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Posted on Jan 06, 2011
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Dec 05, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Cant get my stand of my tv to mount it on the wall can you help?
If you turn the set over you will see a set of screws attached to the bottom of the stand (inside hollow area). There also two screws I believe on the back of the unit near the stand area that need to come out. The stand should come off now. But do you really want to mount it on the wall?
Oh well,
Hope this helps
Skyassoc
Jun 22, 2009 | Toshiba REGZA 47HL167 TV
Taking off stand from LG tv to mount on wall
Apr 08, 2009 | Televison & Video
Stand
How do I remove the stand?
Apr 13, 2008 | Toshiba Televison & Video
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
