Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE model # GSH25SGRE Serial # ZG236647 Refrigerator was making a clicking noise yesterday. Thought it was the Condenser fan motor. Replaced it and refigerator and freezer worked. Tried to use the ice dispenser/water this AM and the refrigerator stopped working and started clicking again.
  • alotaxoxo Sep 11, 2010
    I bought a Main Control board but have not replaced it yet as I am not sure replacing it would solve the problem?
    I am now hearing two clicking noises.
    I bought a main control board but have not installed it as I am unsure it is the problem.
    There are two clicking noises now.
  • 3,083 Answers
This looks like bad capacitors on the control board, as the following blog reports by another GE owner:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/21189-ge-side-side-clicking-noise-not-longer-freezing.html
Here are diagrams and parts lists for your refrigerator:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227266
Good luck, hope this works, and thanks for using FixYa.
Posted on Sep 11, 2010
  • 2,272 Answers
Check the water solenoid valve at the back of the ice-maker unit.Remove the ice-maker and check the valve at the back of the unit.Its a dual valve(one unit)One valve for water and one for Ice-making.Remove that valve and clean it and reinsert and check.Notice if the noise coming from that valve section.If yes then replace the valve.But if the noise is not coming from the valve are then recheck the fan motor  which you replaced,If its got loose and causing the noise again from then section.If yes then that can be the issue,Remove the fan motor and its connections and clean it and reinsert.Clean with dry cloth.But as you mentioned that refrigerator is not turning ON,then yes it can be faulty main board,which has to be replaced,The water valve as well as the condenser fan motor both are controlled by the main board.So if both the parts checked ok then the main board is faulty and has to be replaced.Re check all the connections before replacing any part.In many cases it has been noticed that loose connections causes clicking noise.Once removed and reinserted the plug in connections stops the noise,if in-case its due to loose connection.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
  • raj somaiya
    raj somaiya Sep 11, 2010
    Replace the main board and confirm the fault.
    Keep updated with the results.
    Thanks.
    President:
  • 3,773 Answers
Sounds like the compressor relay has bit the dust.
its the part tht fits on the compressor.
Part # (ERP410)
When you remove the old relay and cut the two wires to it
splice those two to the new,more powerful relay (two black wires on new relay to the two wires that went to the old relay)
Instructions are on the pkg to hook to compressor. you can't fail.
Your local parts appliance store will give you a lot of info.
Don't forget to check cond fan next to compressor .
If this was helpful please rate me.
IMUFO2
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refrigerator makes naoise intermitently. Could it
Most cases it is coming from evaporator fan or condenser fan motors. 80% is coming from evaporator fan or condenser fan motor, 5% from compressor and 5% from flow of refrigerant ( gurgling ), 10% from the rest.
Mar 07, 2010 | Refrigerators
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 31, 2009 | PDS22SFS Stainless Steel
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Clicking sound - not cooling
The problem is most likely the condenser fan motor at the back-side/bottom/right of the unit. If this fan is not turning, unplug the connector to this fan (inside the protective cover on the wires near the fan)... if the clicking stops, then this fan needs to be replaced.
What is happening is that this fan has failed but continues to draw a heavy load from the circuit board... It draws enough power from the circuit board to drop the voltage on the circuit board to 5-6 volts and the relays on the board open up and disconnect the power to the fan. The the voltage jumps back up to 12-13 volts and the relays turn back on causing the voltage to drop again and the relays to open.... ON....OFF...ON...OFF..... thus the clicking!
The exact part number for this fan may vary depending on the model and serial number of your unit... My model is GBS22K-BRBBB and the fan part is WR84X10055 and should cost $60-$70 though I have seen it being sold for as much as$130.
Mar 12, 2009 | GE GBS22KBS Bottom Freezer Refrigerator
Clicking noise on GE GSH25SGRE SS
The main controlller board is bad and must be replaced.
Dec 29, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
189 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
