Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washer fills and does the initial agitation but then stops. No clicking, or buzzing, just stops. After awhile it will start again, run a little, then stop again... over and over and over! When I get up in the morning it will be finished. Help!
  • 15,935 Answers
CLICK HERE to see the timer you'll require.
Access yours first and compare - as Kenmore is a "catchall" manufacturer - they put their Badge on other company's products.
Here are some generic instructions to help you access the timer...
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Series 70 fills wit water stops then makes a slight buzzing sound
    The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
    Jun 16, 2009 | Kenmore Washing Machines
    My kenmore washer fills up but then just stops
    it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
    Start with the pump and see if it has sock or something stuck in it.
    Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 90 Series Washer
    Maybe. Sounds like the motor is not agitating in the other direction??? There is a controller on this type of machine which handles the starting...direction of the motor..this is by far the most common for your description.
    next would be the timer or transmission.
    to check trans..grab top lip of bowl it should be locked in both directions. tilt machine back..you should be able to spin the pulley in both directions it not its the trans
    I'm sorry bout the flow of this...not used to doing it like this...think i'm slowly getting better????
    Jan 04, 2008 | Kenmore 24032\24036 Top Load Washer
    Whirlpool ultimate care II stops during cycle
    THe most likely cause for this is either the lid switch or the timer itself sticking.
    Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    48 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
