Question about kawasaki Full Suspension Mountain Bike Men
Never own a jet ski, my son give me one, he is not here to teach me how to start the engine out of the waTER
    Problem Solver:
  • 11 Answers
Just found this website,
http://answers.yahoo.com/question/index?qid=20090801184036AAM0vcN
check it out see if it helps first!
Posted on Sep 11, 2010
Jet ski troubleshooting
what make of ski ?? does it get water in the engine all the time ? more info please ?
Feb 15, 2014 | WSM 1998-1999 Yamaha Gp 800 Cc Jet Ski...
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
My Yamaha Jet Ski 750, turned over Bro.. my Jet Ski, Yamaha 750, turned over and after that.. I pulled out of the water took the spark plugs out, put DW40 in the cylinders and nothing happened.. the e
sounds like you hydro locked it and possibly blew out a reed in your engine intake or worse, you may have bent a crank rod. But before you go tearing it apart make sure all the water is out of motor and theres none in the fuel tank then put in a new set of plugs and see what happens,
Mar 18, 2013 | Water Sport
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
1995 kawasaki 750 jet ski overheats when going fast
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
Aug 26, 2010 | kawasaki Full Suspension Mountain Bike Men
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
Rolled our 2007 800 SXR - ended up upside down. Rolled it clockwise back to upright. Re-started it without looking into engine compartment. It ran 5-6 seconds then stopped. Now the starter can't turn the...
i would remove all of the water and then manually turn the engine over alot without starting it SOON to get the water out of the pistons- if it was hydro locked this might prove quite challenging.
Aug 06, 2009 | 2000 kawasaki VN 2000 Classic LT
Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
Jul 05, 2009 | Yamaha 12V Air Pump
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
kawasaki Full Suspension Mountain Bike Men Logo
124 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
