Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
The fridge is on but will not get cold. freezer either, everything looks like its wrking properly except the temp
  • nickigrindz0 Sep 12, 2010
    thanks for your response. i checked fan in rear and it is working. compressor is quite warm, i unplugged frig for 3 min,turned it back on along with the thermostat but was not able to reset it. i didnt see a reset button or anything. i also cannot find any wires behind thermostat dials so i was not able to complete every task. can you explain exactly how to d these things?
    i jus realized you have wrong info on fridge. i have a ksrs25ilss01 this may help lol
    Genius:
  • 1,622 Answers
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help, this will make your fridge work again...Take care
Posted on Sep 12, 2010
    President:
  • 3,773 Answers
Check the condenser fan in rear
and feel of compressor if it is very hot then its going bad.orneedsa hardstart kit(erp410)
feel if it is running if not tap on thermostat in ref.
turn off thermostat
Unplug fridge for three minutes
Turn on and reset thermostat
If it still does not run. unplug Fridge, take the two thermostat wires off and hook them together. (Thermostat is in ref behind dials and so is the defrost timer if you don't have a card). Turn defrost timer 1/4 turn
if none of this works you may need a service man
or I have written a tip that might be helpful Check it out
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge not cold
you have a fan motor and blade located between the fridge and freezer. What this fan does is regulates the temp of the fridge from the coldness of the freezer. If this fan is out the fridge will be warm. The fan is losacted in the space between the fridge and freezer on the inside near you temp control switch. Look at the top of the fridge on the inside and you will see a set of vents. The fan is located behind these slotted vents. Take care in removing the plastic cover and remove the motor. Take model and serial# to an appliance parts house for proper replacement.
Hope this helped you some
Dave
Jan 22, 2010 | Hotpoint HSS25GFP Side by Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator side is barely cool but the freezer side is freezing properly. Thermostat is turned up to "9"
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 19, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Gsh25vgpccc ge side by siderefrigerator
well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Dec 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
67 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
