Question about Bosch Refrigerators
Bottom freezer model KGU30605GB. Red warning light came on this evening first time with left front side of freezer portion dissipating moderate heat. Cleared out ice formation from fridge unit thinking this might be a cause and switched unit back on. But again, after about 15-20 minutes, freezer unit left side started heating up. Unloaded stuff from the middle and bottom shelves of freezer thinking these might have been overloaded with little/reduced circulation area, but again same phenomena reiterated. Currently observing heat build up rate, but presume red warning light might come back on if left running overnight. Fride/freezer is full of food stuff. Could you kindly throw some light on the possible issue, please? Thanks in advance and regards Sudeepto Bose Mullingar
  • sudeepto_bos Sep 13, 2010
    Heat dissipation has ceased overnight since complain, after reducing further load on freezer and opening door for shorter durations instead of longer ones on day of problem. Assistance no longer needed for now. Thx
    President:
  • 2,047 Answers
The freezer part of your unit usually has an independent line from the compressor. The phenomena which you are experiencing usually is as a result of a leakage in the pipe which runs into the freezer. This leakage usually causes the pressure from the compressor to become reduced and therefore unable to produce cold hence the heating.
The red warning light comes up as an indicator that the temperature in the freezer has become to high. Get a repair expert to trace the line for leakages and block them and also to fill up the gas in the compressor.
Hope this solution has been helpful?
Posted on Sep 11, 2010
Kenmore side by side Refrigerator top portion is not getting cold. The freezer is working and the bottom portion of the refrigerator is cold but not the top portion of the refrig,
the refrigerator simply by transferring the cold air from freezer via circulation fan the temp controls tells the fan to circulate cold air until the thermostat is satisfied I would check to see if the fan is blowing on most models I have seen its located in the left rear wall closest to the freezer above the top shelf
May 02, 2012 | Kenmore Refrigerators
Ihave recently moved my fridge freezer ,and the red alert light has come on,could you tell me what is wrong,thanks
It comes on when there has been a power interuption to warn of a possible thaw of food or that the inside temp was high, it will correct itself within 24 hours or you can push the reset button beside the light to cancel.Please let me know if this works
Jan 19, 2011 | Hotpoint FFS70 Bottom Freezer Refrigerator
The ice maker has stopped working , a red light is flashing.
according to the led flash cycle, you can figure this out. if you open the freezer door and the light flashes two times, that is normal. if you close the flapper on the left side of the freezer, the light should remain lit, and that means that the optic system is functioning correctly. there is a diagram behind the vent panel on the bottom front of the fridge.
Nov 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
The red light next to OVER TEMPERATURE IS FLASHING ...WHAT DOES THAT MEAN? thank you, darlene
it means it's too darn warn in side the frig . or freezer .. ck the coils underneath and the fans . make sure they work . coils may be dirty .. mm hope this may help . feed back pls .. need moder # too give best help ..
Oct 31, 2010 | KitchenAid Refrigerators
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
109 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
