Question about Whirlpool GHW9100L Front Load Washer
Control locked light is on, can not get any buttons to work even after unplugging the machine
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to unlock controled lock
You can try a hard reset.
Turn the machine off if you can
Unplug it from the wall outlet
Leave it for about a minute
Plug it back in.
Always use caution when working around electricity and a washing machine
Are there any lights showing on your machine? What is the make and model of our washer?
Dec 31, 2010 | Whirlpool Washing Machines
The control lock button is light up and the washer won't work.
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 23, 2010 | Whirlpool Washing Machines
The machine's "Control Locked" light is on.
Did you try to push and hold the 'CYCLE END SIGNAL' button for 3 seconds?
May 02, 2010 | KitchenAid KHWS02R Front Load Washer
I own a 4 yr old whirlpool duet dryer and controls locked light came on and can not get it to go off
Look for the End of Cycle button at the extreme right hand side of the console then press and hold it for 3 seconds or until the Control Locked light turns off. The instruction is actually printed right below the button. The control lock is a safety feature of the dryer to prevent settings manipulation during the drying cycle.
Unplug the dryer for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if it's still cannot be unlocked even after the machine is unplugged.
Apr 11, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked. How do I unlock it?
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. The End of Cycle button is located at the extreme right of the console. Unplug the machine for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if the control cannot be unlocked even after the machine is unplugged.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on, machine is currently inoperable.
Push and hold the end of cycle button for 3 sec to lock or unlock control panel. here is the manual if you need.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606218.pdf
Good luck and please rate FixYa!
Apr 13, 2009 | Washing Machines
Control lock
look closely at the control panel there is a button marked"control lock hold for 3 secs." probably a small pic of lock on it as well, simply hold for 3 secs to release it,
Jan 10, 2009 | Washing Machines
Control locked onHe3
try unplugging then hold power button down for 10 secs or so with power removed this may help reset the control bd may even try holding lock button down longer than 3 secs i usually hold until light goes out
Jun 25, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
