Question about GE Kitchen Ranges
I need a schematic hook up for 49624 4 wire power cord
  • 101 Answers
Check with ge applicence,com
Posted on Sep 12, 2010
Hook up black white and green ground
hooking up 120 volt you must change the brown and white wires to different positions see the side of the motor for the low voltage schematic then your black wire goes to F1 and white wire goes to F2 with other white wire then green goes to the metal case under the green csrew
Jun 20, 2014 | Pentair One - Speed 1.5hp 115/230v Dynamo...
Riccar 8955 power cord schematic
The black wire goes to the switch, the white cord goes to the white wire in the vacuum.
Feb 14, 2014 | Riccar 8955 Upright Vacuum
Parts schematic for riccar 8920 vacuum
I am looking for a new motor for my 8920 Ricaar Vacuum. All else works fine.
Jul 13, 2012 | Riccar Vacuums
The Dryer won't run. No power at contols at the top of the dryer. Getting shock if you touch the dryer and you are grounded. Example : If I take my multimeter and touch one probe from the dryer cabinet...
Need to open the panel and inspect inside the dryer. Obviously the power cord is not a problem, but some wires connecting to the circuit board panel got loose then caused such a problem. Use the volmeter and follow the schematic to check the proper terminals.
Sep 20, 2010 | Dryers
Need wiring schematics for Haier HWR12XC5 AC
My friend ... you are doing a simple repair ... you don't need a wiring schematic to replace this power cord. When you get the unit open ... you will find the other end of the ripped cord ... black goes to black, white goes to white green goes to green or ground. In fact ... you will trim the end of the cord and reattach it using either crimp connectors or wire nuts.
Thanks for your interest in FixYa.com
May 31, 2010 | Heating & Cooling
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Power cord was pulled loose from internal connections.
The pressure switch will have 4 terminals. 2 marked "line" and 2 marked "load". You must hook the power cord to the "line" terminals and you must hook the compressor motor cord to the "load" terminals. MAKE SURE THE BLACK LEADS MATCH EACH OTHER,AND THE WHITES MATCH EACH OTHER.
If this does not make sense DON'T PROCEED. contact me or an electian.
Mar 28, 2009 | Air Tools & Compressors
I'm trying to put a three-wire power cord into a dryer and the cord and dryer have no schematic. I hooked the three wires to the three terminals, but have a concern that the neutral wire should be hooked...
The following link explains how to connect a 3-prong and 4-prong power cord to an appliance. Since you did not post your location, I'm assuming this is for the United States:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope you find this information helpful. Please read through the link thoroughly. If you still have questions or concerns, please let me know.
Sep 24, 2008 | Dryers
Open Questions:
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
