Question about Goodman CKL60AR60 Air Conditioner
Does the a/c have a reset botton? - Goodman CKL60AR60 Air Conditioner
  • 407 Answers
The best way to reset these units are to find the breaker and turn the power off to the outside condenser and the inside furnace. There will be two different breakers. Just wait a few seconds and kick everything back on. This usually doesn't fix anything, but will give you a place to start if you can see what it does before it stops working or if it just doesn't work at all. Hope this helps and good luck!
Posted on Sep 11, 2010
Honeywell reset botton stuck
Buy some WD40 or CRC spray and using the thin tube that comes on each can, spray around each button to get penetration into the spring inside. Pump the switch until it loostens. If this doesn\'t work you need a new switch!
Dec 31, 2012 | Honeywell Heating & Cooling
How to renew my passport?
check on the router there would be a reset hole or reset botton, you can press that reset botton or inset some pointed device into the reset hole and reset the hole
Aug 09, 2011 | Computers & Internet
My Switching adapter does not work. Where can I obtain a new one?
Good day
hi you dont need to wory about the switch.. you can use your reset botton for the mean time
because the reset botton is same in on/off switch..
the reset botton have 2pins same as the on/off switch i hope i help you...
May 31, 2011 | Computers & Internet
Hi, I have a problem with incoming calls: I can phone but I can't receive calling form others...the phone doesn't ring, while the calling phone is ringing as normal. Resetting the phone can help me? How...
format the set.press *3 and call botton.by press those bottons switch on the power botton.dnt release the power botton unless u find formating on the screen.see that the battery is fully charged.ater completing the formating the phone restsarts
Apr 17, 2011 | Nokia 6600i Slide Cell Phone
# 3 and H Flashing ... will not do anything else ?
TO RESET THE MACINE PRESS THE ORANGE BOTTON (C),PRESS THE BOTTON UNDER THE AUTO DENSITY LIGHT,RETURN TO THE FIRST ORANGE BOTTON THEN THE AUTO DENSITY BOTTON, YOU HAVE TO BE FAST WHEN PRESSING THE BOTTONS, ALL THE LIGHT ON THE DISPLAY WILL GO OFF THEN PRESS 14 AND PRESS THE GREEN PRINT BOTTON,THE MACHINE WILL RESET AND START TO WORK, BUT IF THE PROBLEM COUNTNUE CHANGE THE FUSER UNIT.
Sep 10, 2010 | Sharp AL-1000 Copier
Give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
How do you reset the change oil light?
Pull the fuse panel door of on the driver's side. Turn car off. While key is in the ON position, press the red reset botton
When tha Change Oil light starts to flash, press and hold the reset botton again. Reset is complete when you hear chimes
Jul 16, 2009 | 2003 Oldsmobile Alero
Reset botton in this HL-2140 PRINTER
There isn't a reset button, try power switch.
Jan 14, 2009 | Brother HL 2140 Laser Printer
How to reset and format
*#7780#
do rply
Jan 12, 2009 | Nokia 6600
Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Jun 23, 2008 | Siemens SX66
Goodman CKL60AR60 Air Conditioner Logo
53 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
