Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stopped and light is on for control lock
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
My washer won't start because the Control locked light is on Help?
on the control panel you should see a button marked lock or child proof or with a pic of lock or key...  hold in for 3 - 5 secs and that should unlock it.  it's there to stop the little ones from messing with the washer since the controls are in reach if inquisitive hands.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't turn on and the light by "control locked" is lit up.
Control lock is a feature to lock your control from anyone changing your setting or stopping the washer from being shut off after you have selected a cycle. There is a subscript under one of your option buttons that says control lock hold for 3 seconds. Hold this button in for 3 seconds or so and the lock should turn off. It was probably pushed by accident or someone was leaning on it. If this doesn't solve the problem please post again.
Please rate this post. Thank you.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The control locked light is on. No other buttons
push one button (any / not stop) push 4 sec, rel 4 sec, push 4 sec, rel 4 sec that will send in to self dig
Sep 30, 2009 | Kenmore HE2 Plus Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Control lock light on
Hold the noise control button in for 4-10 seconds.
Jul 21, 2008 | Whirlpool GHW9100L Front Load Washer
Control Panel
check your owners manuel should tell you how to un lock controls wont be an obvious button as its a safety feature
Dec 31, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
