Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
The tv was unpugged,when we turned it back on a green light was flashing then it turned to a flashing yellow and eventually shut off.We cannot get it turned back on even repeatedly unplugging and plugging back in
  • 3 more comments
  • timlongbotto Sep 11, 2010
    Hi The tv is6 yrs old,we replaced the lamp last year (spring of 2009)
    the power indicator flashes yellow
    Hi
    not sure if you got my answer but it's power indicator that turns to yellow
    as soon as i turn the tv on it flashes green about 80 times then flashes yellow about the same number of times then the power shuts off after that.there's also a flashing red light on the lamp while the indicator light flashes
    there was no pause in the flashing of the power indicator
  • 10,594 Answers
I need to know how old is this Panasonic PT-50DL54 tv and when did you replaced lamp last time in tv?
Let me know above info to provide you helpful info.
Thanks.
Posted on Sep 11, 2010
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Sep 11, 2010
    OK, is it power indicator that turns to yellow or its Temp or Lamp light on tv front that lit?
    Power indicator should flash in red and please count its flashing as it is an error code that has info about problem section of tv.
    I got your comments, please count power indicator flashing from long pause to pause
    OK, it is lamp in tv that either dead or broken and need to be replaced.
    Please check lamp in tv and replace it.
    Correct, if lamp got dead, lamp light will lit on tv and tv shuts off after some time.
    Power indicator will flash in specific order if tv got hardware problem other than lamp.
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Just replaced bulb and the tv still does not work? the green light flashes 9 times and the red light is solid
Howdy;
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Yellow power light will not turn green
It sounds like U have a bad box. This seems to be the most common problem with them, besides not picking up all the channels.
May 01, 2009 | Televison & Video
TV won't turn on
sounds like the main board has an issue
Jan 18, 2007 | Samsung LTM1775W 17 in. LCD Television
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
