Question about Toshiba Satellite A75-S211 Notebook
My Toshiba Satellite laptop has an issue with the video - the entire screen goes white. It happened a few times and I was able to use it for a period of time after it sat for a while, but now it goes white right at boot up. I'll see the initial Toshiba startup screen and then the whole screen just bleaches out. I've tried plugging in a separate monitor in case it was a screen display problem, but the monitor does the same thing. This leads me to believe that it's a video processing error. Or could it be a hard drive problem? I've also tried the recovery disk, but the screen still goes white, so I don't think it's a virus. Any solutions? I have done open heart surgery on the thing several times, until I finally replaced the DC jack with an external on a cord. If the solution can be fixed by replacing a component, I'm capable of that.
    Guru:
  • 689 Answers
Make sure the polarity is correct on your connectors,you can permenantly damage your pc if this is overlooked
Posted on Sep 11, 2010
Toshiba Windows 7 satellite pro. screen goes
DO NOT OPEN/CLOSE THE SCREEN ANYMORE(or move it at all)
Your laptop is damaged from the hinges which is a pretty common issue
The only solutions would be to:
1) plug in a monitor
2) buy a new laptop
Sep 08, 2013 | Toshiba Computers & Internet
Hey i have a toshiba satellite L305-s5933\r\nand i have white or grey screen .i am ready replaced the screen and the lcd inverter and nothing happened. can anybody help me?
This could be a problem with your video card. If you have an actual removable video card then you might try to replace it. If your video card is built onto the mother board, then you are going to be in real trouble. At that point it might not be cost effective to try to repair it. Of course, since this will likely mean purchasing a part, Toshiba would likely help you to diagnose the issue since it will lead them to a sell. Hope this helps somewhat. Best Wishes!
Mar 29, 2011 | Toshiba Satellite L305-S5933 Notebook
My Toshiba A665-S6086's screen was blue and a redish pinkish earlier today and I have rebooted it a bunch of times. I can't figure out what the problem is. Is it something with the backlight?
Hi. Thanks for your question.
It is more likely that Inverter went is in your screen. They are relatively cheap and not that complicated to replace. To determine that it is your screen that is at fault you need to connect your toshiba to external screen. If the same things happen it is your Graphics card that's at fault. If it don't it is your inverter or connection/cable. When backlight goes bad entire screen becomes dark/darker then normal. Please see this video to have a look at inverter and where it is in your screen to get an idea.http://www.youtube.com/watch?v=S87niyGJfPs
Do not hesitate to ask more questions if this is needed. Thank You for using FixYa
Dec 12, 2010 | Toshiba Satellite A665-S6086 Laptop
My toshiba laptop screen goes white on startup. However, it does work OK with an external monitor. I replaced the lcd screen and still get a white screen. Could the inverter be the problem?
Had same issue, i replaced both the cable and the screen with 2 new screen and cables but still had the issue. my guess is its the connector on the motherboard where you plug in the LCD cable because my webcam dont even work (dont see it in device manager and my cam gets its power from the lcd cable)..
Jun 14, 2010 | Toshiba Satellite L305D-S5904 Laptop
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
I have a toshiba Satellite L305D-S5900, sometimes while i'm using my laptop my screen became white with color stripes, then my laptop restart automatically. this happens when i plug in my cousin's external...
I had experienced similar problems with toshiba satellite pro M200. the problem is on the hardware on the IC chipset. You may consider to immediately send to toshiba for repair.
Usually this happens when a laptop running a pretty heavy process on I/O
Toshiba Contact Information: 800-457-7777
Mar 02, 2010 | Toshiba Satellite A200-19501F Notebook
White Screen Issues on Toshiba M115-S1061
connections could be good in ribbon cable
but still needs to be replaced
the white screen indicates that the inverter is still good
if the laptop works with desktop monitor, then video card is good
if you tap the lid to the lcd and it goes on and off ,ribbon cable for sure,
everytime you open and close the screen , it tugs on the ribbon cable also , only tape holding this in place
Jul 19, 2009 | Computers & Internet
Display Issue
Toshiba makes a great laptop but the display video or lcd seem to go bad very quickly I have replaced the lcd in many to solve this problem but be aware a few also had bad video cards (unlikley in your case as the external video is fine) it would seem as the lcd panel has gone bad on yours. the average replacment is around $100.00 to $300.00 depending on where you purchase from.
Oct 24, 2008 | Toshiba Satellite M115-S1061 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite
I had two Toshiba laptops, one changed the mother board twice, went back to the shop 5 times. it is hard to find out why, that why Toshiba got suit a couple years ago.
Jul 10, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A75-S211 Notebook Logo
171 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
