Question about Sunbeam Refrigerators
Model SR3005G3B Seriel E0800315830004625 Stop running. I hear a click and it sounds like it tries to run but it does not. Any trouble shooting I can do or is it the motor. Thanks Allison Odom
2 Suggested Answers
kdrake84
  • 262 Answers
SOURCE: sunbeam sr3005g3b stop working,,hear clicking
This is a common issue....but this being a compact refrigerator I really couldn't tell you if it is worth repairing. The issue is with the compressor or a part of the compressor. The relay is bad,around $50.00
But this unit or one comparable can be purchased for $80.00-$100.00
Let me know what you would like to do....repair or buy one.
Keith
Posted on Feb 19, 2011
Trouble shooting 1990 toyota corolla fuel system, car runs then stop
To trouble shoot the fuel pressure you will need a fuel pressure tester, now if you dont have one start the vehicle (if it starts) open the gas cap and listen for the fuel pump it should humm and you will be able to here it. with thhe vehicle running you should be able to hear it and if it shuts off the car will stall, if it doesnt and the vehicle stall out you need to look elsewhere
May 29, 2011 | Toyota Corolla Cars & Trucks
Neither the freezer or the fridge is cooling. We replaced the defrost control which had a burned out section, but nothing. We have noticed for a little while that the fridge made this strange sound like...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | KitchenAid KSRD25FK Side by Side...
I have a Maytag MZD2766GES refrigerator and it stop cooling. It has a continuous click sound near the compressor like a relay device. I changed the running capacitor and the click sound every 2 1/2 minutes...
Refrigerator
heatman101
Feb 24, 2011 | Maytag MZD2766GES Side by Side...
Kenmore Elite refrigerator model 795.5882 - frz stop frz and refrigerator stop cooling
Refrigerator
heatman101
Feb 01, 2011 | Refrigerators
I turn on the fan in the bathroom and as the fan gains speed, I hear a clicking sound as it the fan blades were hitting something, and it sounded like it was solid. So I took off the grille and the light...
Are you tightening the grill to the point that it is pulling itself up to touch the fan or is it pulling something down to touch the fan? I would take the grill off and with the fan running, pull and push on the points that hold the grill in place and see if that action causes the fan to click. If it does, you need to trouble shoot from there. If not, an exorcisim might be in order.
Sep 12, 2010 | Home
I came home this a.m. from running errands and my Hotpoint refrigerator, specifically the freezer, was making a loud buzzing sound. How do I get it to stop?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 31, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Came home car running fine next morning no start
try changing the ignition module ,not sure on this model but i think its inside the dist
Dec 13, 2009 | 1995 Honda Civic
Fridge runs when it wants to.
there is some problem in compressor or relay
Mar 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sme problem but more
I do not quite understand your description. However, the motor switch is underneath the deck and is very sensitive to adjust if you have to.
Try starting from scratch with no record on the turntable, the protector over the stylus. and the arm lifted with the cue button. The motor should not be running.
Gently move the arm towards the platter. The motor should start up.
Continue gently moving the arm across the platter slowly until you hear a slight clicking noise.
The arm should try to lift (it's already up) and return to the rest - it will stay up, of course.
After one more rotation of the platter the motor then switches off, or is supposed to at least, by a cam under the platter. You should hear the click as it does so.
It is all a matter of adjustment, and any knocks or bangs the deck may have had may have changed the set-up.
The STOP button you mention is so that you can start the arm lift- and -return cycle at any point on the record. It is not a switch.
Jan 23, 2009 | ION Audio iTTUSB Turntable
Refrigerators Logo
101 people viewed this question
Top Sunbeam Refrigerators Experts
paul
paul
David Spradling
David Spradling
Terry
Terry
Are you a Sunbeam Refrigerator Expert? Answer questions, earn points and help others
