Question about Whirlpool Heating & Cooling
My outside a/c is not working.what should i do?
    President:
  • 3,074 Answers
You will need to check and make sure you are getting power to the outside unit at the contactor. If you are then you will need to see if it pulling the contact in, 26 volts, if it is not pulling in contact and has the voltage it is the contactor, if the contact is pulled in then make sure you have voltage going to the fan motor, if you do then it is the fan motor/capicator. Hope this helped Tim
Posted on Sep 11, 2010
Will not put out heat
Remember, for an air conditioner to PUT OUT HEAT-- (as HEAT PUMP) -- there has to be some HEAT outdoors, to make the process work...
So-- ask yourself-- How cold is it outside?
How cold was it outside, the last time that my AC worked good as a heat pump?
Possibly the coil outside is all frosted up?--
Shutting it off, and letting the outside coil defrost might help-- but-- the basic law of physics still stands: To get heat inside-- there has to be some heat outside! (Likely your unit won't give you much heat inside, when it is below 50 -- or for sure-- below 40 degrees outside!)
Give us a few temperature readings- inside and out, and then gives us clues as to what is running, and what is not-- maybe we can trouble shoot deeper. Is the compressor running?-- does it sound like it is actually working-- or just running-- sort of like 'running but not really WORKING'?
Let us know--
Mack B
Jan 18, 2011 | Samsung Heating & Cooling
Air conditioner suddenly stopped working and my outside temp on dash reads at ( - 40 )ever since.heater works fine
the sensor that reads the outside temperature may be the problem.The computer will not turn on the a/c if it is 40 below outside.
Apr 14, 2010 | 2008 BMW 528i Sedan
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Pix 515E inside to outside translation problem
Dear Kiran,
What is the name assigned for isp 1 as well as isp2.
for your reference kindly find the sample configuration......
ISP 1:
interface ethernet 0 100 full
nameif outside security-lvl 0
ip address outside 203.193.129.132 255.255.255.240.
nat (inisde) 1 (local network)
global (outside) 1 203.193.129.133
route outside 0 0 203.193.129.129.1.
regards,
mani.S
Mar 09, 2009 | Cisco PIX 515E Firewall
Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
