Question about LG DLG2524 Gas Dryer
No power on lg gas dryer - LG DLG2524 Gas Dryer
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Lg dryer dlg8388 , with power on drum runnng but no heating up, i'll check continuity in the igniter and is ok. don't lnow what else to check.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Aug 25, 2011 | LG DLG8388 Dryer
I can't tell if it is a gas dryer or electric
I believe if it's electric, you have a 220 Volt power cord. If it's gas, 110 Volt power cord. Also, look to see if there is a gas line hooked up behind the dryer.
Hope this helps!
Nov 21, 2010 | LG Dryers
My LG DLEX2910V dryer runs on and the drum spins but it doesn't heat up. It's only 3 months old and I have checked the vent and the power connections.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | LG DLEX2901V Dryer
My LG dryer is electric, model# DLE3733W The heat doesn't work, all lights on the panel come on according what I set it at. I can then unplug the power supply and plug back up and the heat works until the...
heatman101
Nov 06, 2010 | LG DLE2532W Electric Dryer
My lg dlg7188rm gas dryer will not heat. the gas
Sounds like you need an ignitor part number 5318EL3001A but you will need a gas technician to work on this legally. Best off to call a reliable service company such as Sears.
Feb 01, 2010 | LG DLG7188 Gas Dryer
Gas Dryer DLG5966W pilot light
The power should turn on a electric igniter once the gas has reached the heat chamber and regulator. If not let me know soon the model number of your LG dryer so I can help you better, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 09, 2009 | LG Dryers
My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Mar 15, 2008 | LG DLG5932W Gas Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
LG DLG2524 Gas Dryer Logo
94 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
