Question about Swintec 7040 Typewriter
Swintec 700 typewriter
When you turn it on it just beeps
  • Anonymous Jul 29, 2008
    I have a swintec 8016 that beeps when turned on and will not allow me to type. It can be moved manually when in the off position
  • 478 Answers
Check if the carrier will move by hand when turned off if it does wipe the carrier rail with a cloth and light oil .
Posted on Jun 04, 2008
SWINTEC 7040 TYPEWRITER PLUG IT IN TURN IT ON ALL IT DOES IS ONE LONG CONTINUOUS BEEP
If this has been out of use for some time move the carrier back and forth a few times then spraysome WD40 on the silver shafts it slides on.
DickyO
Sep 29, 2011 | Swintec 7040 Typewriter
As soon as I turn our Swintec 2640 on it starts beeping very rapidly.
Be sure the printwheel doesn't have any bent or broken spakes. Try it without the bribbon and correction tape to see if they are hitting the P/W.
DicyO
Feb 15, 2011 | Swintec 7040 Typewriter
Swintec 8016 Typewriter making grinding noise all functions froze
Try some WD40 on the silver shafts that the carrier slides on they do get very gummy.
DickyO
Apr 26, 2010 | Swintec Office Equipment & Supplies
Swintec 640 margin release
If it is the left margin, you touch the carriage return button to find the current position of the left margin, then touch the mar release button and backspace to the new left margin location, then depress the left mar key. You should here a beep. You are done.
Jul 22, 2009 | Swintec 7040 Typewriter
I have a swintec 600 wont stop beeping
Usually means there is a problem on the main board. Could be the printwheel is not installed properly.
Jun 04, 2009 | Swintec 7040 Typewriter
Swintec typewriter 7040
Try spraying some WD40 on the silver shaft the carrier rides in and move it back and forth by hand with the power off.
DickyO
May 19, 2009 | Swintec 7040 Typewriter
When turned on - a beep is all i get-keys won,t work at all. 7040 swintec typewriter
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
When i turn it on it will beep every letter i enter but won't type anything it is a swintec model-600
try putting the machine in test mode. You can do this by holding down the margin release key while turning it on. Keep holding it down until it starts typing by itself. Then turn it off and on again and see if it works.
Mar 07, 2009 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
83 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
