Question about Refrigerators
The strip between the doors gets real hot. so hot you cant touch it everything seams to work ok other than that.
    President:
  • 3,773 Answers
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 11, 2010
The front of fridge frame where both doors shut on it and the coresponding door seals are very hot to the touch but fridge seems to be workinf ok
Hi and welcome to Fixya. I am Kelly.
When the front of a unit is getting very warm to the touch it means that the condenser coils in the back are not being cooled properly.
Open the rear fiberboard cover in the back of the unit and check for lint in the coils and that the condenser fan is running when the compressor is on. Most of the time it is just lint build up on the condenser coils causing this symptom. However the fan can be stuck or not operating. If it is stiking or running slow you can lubricate it with Union 76 turbine oil / Zoom spout turbine oiler. DO NOT use regular oil or the motor will eventually stop working.
I am pretty sure if you clean everything up in the back of the unit that it will work just fine.
Thanks for choosing FixYa,
Kelly
Jun 24, 2011 | Refrigerators
The front of the divider between the freezer secion and the refrigerator section is very hot to the touch. What could this be ? Everything else seems to work fine. Thank you !!
Remove the front grill and clean the coils of dust , pet hair , etc . Also pull the refrig out and remove the lower back panel . Check the cooling ( condensor ) fan there to see if it is running or blocked by insulation or any object . If not blocked or turning , replace the fan motor .
These are the only reasons the center strip will get very hot .
Apr 11, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
It keeps shutting down under a code 2 which is motor overload
make sure oillevel is ok make sure cooler is clean make sure air is going trough cooler(fan works) also means doors and panels closed. if that is all correct, there have to come out a lot of hot coolingair out of the machine. otherwise the thermostatic 3 way valve doesnt function open for about 1/2 inch or replace
Sep 08, 2009 | Ingersoll Rand UP6-20-125 120 Gallon...
Outside door seams are hot to touch
This is because the mullion heaters are on. This is a system designed to dry up sweating that occurs on the outside of the box in high humidity. Check to see that all the door seals are tight.
Aug 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
My Subzero bar frig feels quite hot around the edge that touches the rubber and it is making the rubber warm as well. Everything inside is cold, and it is making ice as usual. I think I sense a smell of...
as with alot of refrig units the rubger strip has a warming coil that keeps the door from sticking they keep an even warm temp so as opening and closing the door easy there could be a burn spot in the strip and causing the strip tp be warmewr than it should be almost hot should call a fridge expert after you convince your other half there is a prob normally most fridges have a plan magnetic strip to seal the door
Aug 22, 2009 | Refrigerators
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
