Question about Jenn-Air Refrigerators
Side by side fridge and items continue to freeze in the produce drawer
  • Jenn-Air Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Kenmore side by side fridge- bottom drawer of
The crisper can freeze when air leaks around the base of the duct assembly. To prevent this, the air tower will need to be removed (see picture). Disconnect power to the unit first. All the shelves and drawers will need to be removed, to access the tower. With the air tower out, now run a bead of silicone on the floor where the tower sits. Now replace the duct on top of the sealant to make a tight seal and prevent the air leakage.
Posted on Sep 20, 2011
I have an admiral gc2224gekb side by side. The ice machine isn't producing ice and also the fridge is freezing up
First, check to see if the airflow is blocked at the back of the fridge compartment as this also may cause the lower items to freeze. Fridge freezing is usually the malfunction of the damper swing door or the circuit controlling it. A failure of the temperature sensor in the fridge could be the cause. We just had ours replaced this year [on extended warranty]
Sep 22, 2016 | Admiral Refrigerators
Fridge looses temperature
Make sure the two vents from the top of the fridge that run into the freezer are not blocked or obstructed in anyway, that's what the problem was in ours. Also do not allow ice to build up on the vents in the freezer.
Jan 03, 2012 | GE Profile 26.6 cu. ft. Side-by-Side...
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Why is everything in the refrigerator freezing, and, why doesn't the door & doors (side-by-side) close tight?
Sounds like your door or doors are being held open by an object inside. This is causing the cooling system to run constantly and thus freezing items in the fridge. Check that the shelf under the ice drawer is overpacked. the dispenser runs inro things on the shelf right under that storage compartment occasionally on my fridge. Hope that helps.
Jan 28, 2011 | Frigidaire FRS26H5AS Side by Side...
My refrigerator produce drawers are freezing all of my produce. I have adjusted to low to high humidity on the drawers and it doesn't make a difference. What is wrong?
Make sure the fan in the freezer is running to circulate the air through the fridge. The cold air will settle to the bottom if it's not. Make sure the vents from the freezer to the fridge are open. There's one at the top and bottom.
Make sure the dampers to the vents open and close when you adjust the temp.
Feb 10, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezes produce in bottom drawer
Is the drain hole at the back of the fridge (Inside) clogged up with ice or gunk.... get rid of all the ice built up around the drain and on the bottom drawer
Dec 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
Wall between fridge and freezer is very hot
I understand you are a little irritable about your Maytag. If you would like the service manual or one on one help free free to let me know. Your refrigerator is a complex refrigerator. But quality is Maytag. They are the only company that I know that will go out of the way to insure their customer is satisfied. If you would like the service manual or personal assistance, please let me know, Sea Breeze
Jul 11, 2009 | Maytag MZD2766GES Side by Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Refrigerators Logo
53 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
