Question about Wagner GX08 Airless Spray Gun
Can I replace a wagner G-05 directly with a wagner GX-08 gun?
4 Suggested Answers
SOURCE: Need instruction manual for a ''Wagner 404 Plus'' airless spray gun
I cannot get the sprayer to prime or spray
Posted on Aug 10, 2009
  • 98 Answers
SOURCE: GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Posted on Feb 21, 2010
SOURCE: I have a wagner power
The two holes are where the fitted, dual hose(meaning two hoses together- thus the two holes for the oil) is inserted on the underside of the trigger gun assemply. To do this, simplyh "Tip the sprayer up side down, put a small amount of oil into both holes" on the Gun assembly "and trigger the sprayer briefly".
Any light household oil will do.
That is what the manual states.
Posted on Aug 20, 2011
Need instruction manual for a "Wagner 200" sprayer
Owner's Manual - Wagner
www.wagnerspraytech.com/fileadmin/user_upload/wagner.../0525800_eng.pdf
wagner power painter 200 series manual - download - Google Docs
https://docs.google.com/document/d/.../edi
Oct 20, 2016 | Air Tools & Compressors
Wiring diagram for wagner 905 steamer
Wagner Power Steamer 905 Manuals
www.manualslib.com > Brands > Wagner Manuals > Steam Cleaner
Wagner Power Steamer 905 Pdf User Manuals. View online or download Wagner Power Steamer 905 Owner's Manual.
Aug 29, 2015 | Wagner Spray Tech Wagner Power Steamer 905
I bought new wagner model HT3500 a few years ago never used until now pulled it out of the box it does not stay running. is there a call back on them?
I was given a dead HT3500. Holding the power switch down made unit lights rapidly blink and motor start/stop.
However, before starting repair refer to the HT3500 recall notice.
http://www.cpsc.gov/en/Recalls/2009/Wagner-Spray-Tech-Recalls-Heat-Guns-Due-to-Fire-and-Burn-Hazards/
Assuming your gun isn't in recall, the repair involves dis assembly and replacing the 470uF 10V electrolytic capacitor on board (it is a tall cylindercal plastic covered part.) Replaced it with a 470uF 16V rated at 105*C. If you are handy with a pencil solder iron and solder removal tools, it is a 5 minute repair. Any electronics technician or ham radio buff can do this job.
Jan 31, 2013 | Wagner 0503040 MODEL HT3500 Digital Heat...
I have a wagner power painter 355E and the directions said to put oil in the 2 holes in the gun. Where are the 2 holes?
Where the raised tips of the tubing goes into the gun,
directions state ,"Apply a light coat of oil."Tip sprayer up side down (so handle is sticking up) and the underside where the two holes where the ditting dual hose go in there: This is where you put a small amount of oil into both holes and trigger the sprayer briefly
May 08, 2011 | Wagner Power Products 0154842 Medium Spray...
Need an owners manual. Would settle for a scanned
One owners manual for Wagner plus 404. :) Download is available here.
If this answer helped, please vote. Thanks.
Jun 14, 2010 | Wagner Power Products 0154842 Medium Spray...
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
When i start spraying with the wagner 1800 globs of paint shoot out. I replaced the atomizer but it didn't help
try using a different fluid to see what the gun does.
most of the time playing with stroke of the needle (trigger) and your atomizing air pressure will correct this.
Dec 20, 2009 | Wagner Air Tools & Compressors
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
Wagner GX08 Airless Spray Gun Logo
127 people viewed this question
Top Wagner Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
 Andy
Andy
Level 1 Expert
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
