Question about Sport & Outdoor - Others
I have ProForm 6.0 GSX and when using for walking the belt slips and i can make it stop while sharp noise is generated. If i get out of walking then the belt continues moving. The moving of belt gets stop by my weight or by stopping moving my legs at same speed of belt. Is this normal maintenace required or it is damage ? How can i fix it ? How or where to get such maintenance or repair instructions ? Thank you very much !
  • 95 Answers
SOURCE: Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Posted on Aug 01, 2009
  • 64 Answers
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Posted on Nov 18, 2009
SOURCE: I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Posted on Dec 30, 2009
  • 15 Answers
SOURCE: I have a Proform XP 550s and the belt skips/slips
I would remove the hood first covering the motor (Usually 4-6 screws) so you can isolate the problem. Now you will be able to get a good look at what is going on underneath. If when you put weight on it the you see the motor keep spinning but the drive belt stop then you need a new one. You could temporarily tighten it until you replace it but it's probably ready to go. If the drive belt and front roller keep turning and the walking belt stops then replace the walking belt.
On mine I had to replace the drive belt and the walking belt. I went with the cheapest fix first (drive belt which was slipping) then I could still stall the walking belt but had no way of knowing that until I replaced the drive belt.
I guess if it's the motor you'll be able to tell that too by watching because it'll bog down.
Parts at TreadmillDoctor.com for me anyway. They have both online and by phone troubleshooting support.
Posted on Jan 25, 2010
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
Posted on Jan 26, 2010
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
How do I fix a problem with the belt slipping?
hi there
it could be 2 things of this problem
1 walking belt slips easy ti fix
1th step; put treadmill in speed of 4 mph and step on side and try with one leg to stop it (be carefull) if you see walking belt stops with align key give more tension from the back of treadmill rear rollers by turning both bolts clockwise same degree with small turns till stops
if it does not help it is probably drive belt
you need give more tension on motor by using 9/16 wrenches
Nov 22, 2010 | Proform Sport 1000 Folding Treadmill...
Belt slips and somtimes stops on me while walking.
hi. if the belt slips and stops when your walking its a sign the you may need a replacement belt. and if you smell motor burning after you have been on for a while that is a sign that a/ you have no oil left and b/ your motor is slowley packing up.hope i have helped.
Nov 11, 2010 | Proform 695 LT Treadmill
I need to tighten the belt, it keeps slipping while walking on it
Unplug unit then remove motor shroud then do the following: If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
1) Adjusting the running belt if the problem: If the walking belt slips when walked on, UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
2) Adjusting Drive belt: Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
May 14, 2010 | Proform 860 Competitor Treadmill
While trying to run the mat/track stops or studders momentarily.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 10, 2010 | Proform Crosswalk 500 Treadmill
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
We have a Proform Sport 1000 treadmill which when you get on it the belt slips badly and it hardly moves. The belt doesn't seem loose so is the motor failing?
There is a belt between the front roller and the motor (drive belt) that is under the motor hood. The trick is to watch the front roller when you get on the walking belt. If the front roller stops with the walking belt, then the drive belt is loose and needs to be replaced or tightened. If you have already adjusted the walking belt, and you can hear the motor, it's the drive belt. There will be 3 screw on the front of the machine, and a couple of screws under the main frame. Tip the unit over to find the screws, and take off the cover. You'll be able to see where the slip is.
Mar 06, 2010 | Proform Sport 1000 Folding Treadmill...
Belt stops when i walk on it
with item going 2mph, stand on foot rails, hold on handles,with one foot try stopping walking belt-look at front roller while doing this-if walking belt slips around frt roller, its the walking belt loose. at each corner there is an adjustment,with proper allen wrench, turn CLOCK WISE one turn EQAULLY on each side!! Then recheck,keep doing this untill it quits slipping-Small moves is best don't crank.
Now on other hand if walking belt Stops with frt roller, its the MTR dr. belt under the hood, to tighten,with 2 9/16th wrenchs, I loosen mtr mount bolt,with one hand apply pressure to mtr, retighten, or have wife apply this pressure with her foot,but don't over tightn-u want to turn belt 1/4-1/2 inch on side. Also check walking lube under walking belt!!
Jan 06, 2010 | Proform 760 CrossTrainer Treadmill
My proform 860 has belt slippage and sometimes stops after a few minutes
I had the same problem and was about to change the walking belt. Instead I removed the 5 screws holding on the hood and adjusted the Reed Switch and took a walk. Whenever I stomped on the belt hard it would stop. I Could now see (because I removed the hood) that the motor continued to spin and the Motor Drive Belt was slipping and was the culprit. Something that I had noticed before was all this fine rubber dust coming out near the left front corner where this belt is. If you see that it's a good indicator the motor belt is slipping and needs to be replaced.
Dec 09, 2009 | Proform 860 Competitor Treadmill
Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Aug 04, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
121 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
