Question about Samsung Televison & Video
When turning on the TV it clicks about a full two minutes before turning on.
  • 201 Answers
This is a common problem with the set. The power supply has 2 or 3 capacitors that are swollen because they can't handle the voltage anymore.Eventually it won't come on at all.If you can use a soldering iron you can repair for several bucks. If you get a TV repair service they may want to replace the entire power supply instead which will cost hundreds. You can verify the problem with a visual inspection of the board. The caps will be rounded or peaked on top unlike the other normal caps which are flat on top.
Posted on Sep 11, 2010
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
I have a flashing menu screen and cant turn it off
Try to do a power reset first by having the TV unplugged from the power outlet for one minute, then do factory reset. Do the factory reset 3 times for a full reset to occur. Once the initial setup screen appears, go on and press the up arrow on the remote then power on the TV. If the TV still does the same thing, the TV would require service. You can click on this link for service options.
Jan 23, 2016 | Televison & Video
We own a Sony FWD-50PX2 television. A few weeks ago it would not turn on. The power is going to the television. When you try to turn the tv on you can hear it pop and the red light showing it is off...
this is a common issue i think. below steps solved this issue for an user.
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 23, 2017 | Sony FWD50PX2/S 50 in. Plasma Television
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Sony Plasma TV
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
Jun 12, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
76 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
