Sanyo DP26640 - can't program it into my cablevision remote control. Have tried every step in the cablevision manual.
2 Suggested Answers
SOURCE: code for cablevision remote control
Hello Monica24g. I also have Cablevision and found the codes I was looking for. I assume you have an Audiovox (fpe1907) television. Here are some codes you can try: 076 103 043 035 224 228 078. Press the "TV" button and the "SELECT" simultaneously for 3 seconds. The IO button will light up. Enter one of the codes, then press the "TV" button again. I hope this helps!
Posted on Jan 05, 2009
I have purchased a new remote for my sanyo tv. the lights on the remote buttons will not light up.
J. if you know the lights on remote are to light up and they do not, it is defective, return for replacement or refund. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sanyo DP19649 Owner Manual Remote Control Operation
How to Program Universal Remote Welcome to Remote Central Universal Remote Control Reviews More
Apr 12, 2016 | Sanyo DP19647 DP19648 DP19649 DP26640...
I want to deprogram the remote. Its a Sanyo model number DP26640
Most remotes use a volatile chip that holds information due to batteries remaining in situation and forget it if left for 24 hours without batteries . Some use a Non Volatile chip that don't need power these have a de-program procedure shown in the manual usually.
Jul 02, 2015 | Sanyo Televison & Video
Whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
Feb 04, 2015 | Sanyo DP26640ARB - 26 LCD HD TV 720p...
How do i program tv for antina
Turn it on and press menu, once in the menu go thru it as the things to do come up, first should be antenna or cable, navigate to antenna and press it, then finish setup.
Nov 15, 2014 | Sanyo DP19647 DP19648 DP19649 DP26640...
How to program m30991 remote to wore on Sanyo DP26640
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 25, 2014 | Sanyo Televison & Video
I bought the Sentry RMC10 Big Universal remote, but I lost the manual. I am not able search code for a Sanyo plat panel tv, Model DP26640-26" Diagonal LCDHDTV
The codes for Sanyo TVs are as follows.
  • 004
  • 013
  • 049
  • 108
  • 110
  • 180
  • 209
If none of them work, you can try the manual code search feature.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Nov 28, 2013 | Sanyo Televison & Video
I cannot get any codes to work for my curtis international tv, using a samsung cablevision remote control.
Do a search function with this remote control. Try to download the user manual to your remote control by internet, for details.
Feb 11, 2013 | Curtis International New Original LED2440A...
What is the code for a Sanyo DP26640 26" LCD TV
Hello
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
1. Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2. On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3. Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4. Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5. Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6. Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
Apr 29, 2011 | Sanyo Televison & Video
Code for cablevision remote control
Dec 05, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
Electro Med Services...
