Question about Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
Little green machine will not spray. Can I fix it?
    Sniper:
  • 67 Answers
Im sorry to say, it sounds broken. you may wanna try hot water it may be clogged ( be careful) if that doesnt work out.... i know of this great site that sells bissell's for like half of retail check it out.....maybe your best solution....http://stores.ilikenew.com
Posted on Nov 17, 2010
    Problem Solver:
  • 5 Answers
Yes according to the model you have look up a schematic on line and take it apart you will see the pump assy the pump # is 6035029 this can be purchased on line i got mine at VacParts Warehouse.com think it was about 14 or 15$
Posted on Oct 11, 2010
4 Suggested Answers
SOURCE: Bissel Little Green Spray Motor
Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
Posted on Mar 10, 2008
SOURCE: little green machine
The pump motor solution worked on my Bissell 1400. I did not have to take the vacuum motor out. I also lubed the motor although it looked like it might have sealed bearings, figuring a little WD 40 couldn't hurt.
Posted on Mar 08, 2009
SOURCE: my little green machine won't spray the solution but it will pick
We had the same problem. After dissassembling the whole machine we could not find a clog or any other obvious problem. The manual suggests priming the pump by putting the solution reservoir in and out a few times. This did not help much. What did work was to raise the unit up a few feet above the trigger while depressing the holding the spray trigger. (That is, use gravity to fill the tube.) After solution was flowing freely, we turned the machine on and it seems to spray fine again.
Hope this helps
Posted on Jul 22, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Little green machine will not spray cleaner
    Have you checked the tiny hole that the spray comes out of. I have one and sometimes it becomes clogged. I take a small needle and run it thru it.
    Oct 09, 2014 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Won't spray solution
    if its not spraying solution there are two possible problems,
    1. the solution carrying line that runs from the unit along inside the hose could be blocked.
    2.there mite be a clog somewhere inside the solution tank or leading from the solution tank
    Sep 19, 2012 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Green machine
    i recommend you that you go to :http://www.bissell.com/how-to-videos/
    and proceed with the troubleshooting guide. Normally this a problem with clogged hose+pump
    God bless you
    Jul 16, 2012 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Biseell little green machine wont squirt water out
    The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
    Thanks and have a good one
    Sincerely, CRTN
    May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
    I also had the same problem as you.
    Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
    I did this a couple of times and it worked. This info I found on the Bissell website.
    Good Luck!
    Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
    Mar 09, 2008 | Bissell Vacuums
    Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum Logo
    348 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
