Question about Lexmark Wheelwriter 10 Series II Typewriter
Wheelwriter 10 Problems
Had my WW for years & years...worked perfectly until today. Turned it on & it won't Return, Backspace, Line Up/Down....I changed the 3 batteries but nothing - zero - Any suggestions? - Andrea
  • Lexmark Master
  • 3,594 Answers
Sounds like a bad keyboard. does it type at all?
DickyO
Posted on May 16, 2008
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Ihome keyboard not picking up most of what I type
Change the cheap generic batteries with Duracell. If it continues to be defective, send it back, or contact them direct. We are Fixya, not iHome.
Support
Dec 01, 2017 | iHome Computers & Internet
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
95 mitsubishi manual. Shifting problems. Changed slave cylinder and bled line and it worked perfectly . Today it won't shift unless engine is off. Should I bleed line again? What else might be wro
Check the slave cylinder is coming out when you push the clutch down ,without my head under the bonnet its difficult to say but either you have lost the fluid or the thrust bearing has now pushed through the pressure plate with the correct pressure .
Jan 30, 2012 | 1996 Mitsubishi Galant
Hot water tank - Bock model 51E Was working perfectly until a couple hours ago and then stopped. I have a red light indicator on and I've pressed the red button reset and the motor started up for...
Call service technician.
Call Boch Phone: 608/257-2225
http://www.bockwaterheaters.com/technical/engineering.html
I don't see a service manual posted on internet.
Without a service manual showing ohm-readings for testing different parts, you are left guessing which part is problem.
Most water heater manuals today recommend yearly service to catch up on most causes for failure including air in fuel line, dirty or corroded burner parts, defective sensor, loose connection, etc.
Jul 30, 2011 | RTO Bock Water Heaters 51E 50 gal 152,000...
How do I get the left margin to change?
Return to L. mar. press and release mar. rel. key, backspace to wanted location, press left mar. key. On a WW3 the machine will not remember the margins when turned off.
DickyO
Jul 17, 2009 | Lexmark Wheelwriter 3 Typewriter
Ty0ping i0n add0it0ional0 0 characters
changed batteris and that worked great. Until this am. Came in and same problem. switched batteries back but no fix. I am sure new fresh batteries each day can't be the solution! Anyone have any ideas
Dec 16, 2008 | Logitech Cordless Desktop EX110
Lexmark Wheelwriter 10 Series II Typewriter Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
