Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
How do i remove PTO clutch assembly from a International 856, also will the PTO assembly from an 1586 and a 856 inter-changable?
How do I remove a pto clutch from a John Deere 757 ztrak zero turn mower
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Dec 28, 2015 | John Deere Garden
I replaced drive belt on troybilt mustang rzt shortly after electric pto clutch stopped engaging
Moist likely you failed to reinstall PTO clutch correctly as it sound the anti-rotation device wasn't installed. When you started the engine it would spun pulling the wiring apart. Hopefully just connector came part; otherwise, you might need to purchase a new PTO clutch assembly.
May 12, 2015 | Mustang Garden
How do I check the PTO switch on my RTZ22 mower?
Hopefully you put back the stabilizer for the clutch assy. If not then it spun the first time you you crank the mower engine and destroy it wiring connections.
If this didn't with the mower not run but the ignition in the on position disconnect the connector at PTO clutch. Now switch on the PTO switch and using a voltmeter (DVM) check for the battery voltage across the two wire at the connector. If voltage is there then the PTO clutch is bad. But if the voltage isn't present then either you have bad PTO or ignition switch or have wiring problem.
Mar 31, 2015 | Garden
When engage pto notice that voltage on battery drain is that cause bad pto
Can be if its coil is partially shorted. These usually 5-7 amps current-wise.
Disconnect the pto clutch wire connector at the pto clutch assembly. Using multimeter do a ohms test on the engagement coil. If it reads less than 1.5 ohms then it is partially shorted.
I have seen clutches to work even pulling up to 15 amps when partially shorted which more than most small engine alternators can produce.
Mar 30, 2015 | Garden
Ariens model 915111. Blades will not engage. Using a light voltage device. I placed the probe inside the socket which was connected to the pto clutch and it lit up. Can you tell me what part needs
If your receiving power at the PTO clutch and it is the correct voltage ie. 12vdc then you will need a new PTO clutch assembly.
Oct 28, 2014 | Garden
How do I replace the Blade Clutch Assembly on a Craftsman mower, model 817.288160?
There is one bolt in center of pto clutch. Its best to have an impact to remove this. If you try to remove with a wrench engine will spin. Remove both belts first. Then simply unplug the PTO, Use impact wrench and remove center bolt and gently pry off. Installation is the reverse order.
Oct 15, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Remove clutch
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Jul 29, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a John Deere L-130 and the electric PTO appears to be engaged even when the switch is turned off and the wiring to the PTO is disconnected. I can start the engine (with the wiring disconnected) and...
Good diagnostic work, uncleparroth! By removing power to the PTO, you've proven that the PTO clutch has stuck/frozen mechanically. If you are mechanically inclined, you can remove the PTO clutch assembly and disassemble it. You could luck out, find something as simple as a broken spring and save a lot of money. Nothing to lose but your time. On the other hand it might not be repairable and you'll have to 'spring' (sorry for the pun) for a new PTO clutch which will cost about $200. Good luck!
Aug 08, 2010 | John Deere Garden
I have a electric pto that come off a cub cadet and the part number of the pto is 5219-25 its a warner. My question is one of the wires have pulled loose in side the magnet are there any way to remove the...
Most likely you cannot repair this as the wire ususally breaks off inside. If you remove the assembly, you can see where the wires go into the potted coil. If there is no excess wire to reconnect to then your only choice is to replace.
Jul 01, 2010 | Oregon Scientific Electric PTO Clutch for...
How to remove the clutch assembly on a 5252E tractor
Remove the primary belt (clutch to deck)
Remove the deck (to gain room to work)
Unplug the clutch harness from the main wiring harness
Remove the bolt in the center of the clutch that secures it to engine
Slide it downward until it is free
Sep 17, 2009 | Oregon Scientific Electric PTO Clutch for...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
484 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Tom Chichester
Rod Newman
Rod Newman
Level 1 Expert
Are you a Farmall Toy Expert? Answer questions, earn points and help others
